They'll do the trick. Though which slots are you planning on using? Open air coolers would be better if you have a good amount of space between them.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
Hello, I was wondering if Reference cooling is enough for 2x 980 Ti's playing 4K? I am planning to fan cool both of them or do I get more fans?
Here is my build: http://pcpartpicker.com/p/yhD83C
I would assume so since the cooler is engineered to cool that card.
CPU: Intel i7 - 5820k @ 4.5GHz, Cooler: Corsair H80i, Motherboard: MSI X99S Gaming 7, RAM: Corsair Vengeance LPX 32GB DDR4 2666MHz CL16,
GPU: ASUS GTX 980 Strix, Case: Corsair 900D, PSU: Corsair AX860i 860W, Keyboard: Logitech G19, Mouse: Corsair M95, Storage: Intel 730 Series 480GB SSD, WD 1.5TB Black
Display: BenQ XL2730Z 2560x1440 144Hz
don't forget that with open air coolers you're tossing the heat back into the case, which is a considerable amount of heat when you're talking about SLI 980 ti. you'd want to make sure your case airflow is decent across the cards, to get rid of that hot air.
