https://linustechtips.com/topic/385049-optical-help/#findComment-5198474
@General_Led
I hate that no one has asked you why........
Why do you need optical out from your computer?
I would assume he needs it for a surround input for a speaker system (hopefully not for a headset)
https://linustechtips.com/topic/385049-optical-help/#findComment-5199030
That's exactly why I'm asking  :) Optical is probably the worst connection these days only because fewer video games are supporting surround sound through it. I have no idea why! But strangely enough, optical is the best for music in my subjective testing.
https://linustechtips.com/topic/385049-optical-help/#findComment-5199073
Lots of things only have optical (cheap Logitech 5.1 systems and the like)
But if it's for a headset then it's just stupid, like surround headsets are
https://linustechtips.com/topic/385049-optical-help/#findComment-5199080
I have no idea how anyone would cope with a 5.1 system that only accepts optical. I was pretty furious when I found out some games just don't support more than two channels.
I thought all surround headsets were USB?
https://linustechtips.com/topic/385049-optical-help/#findComment-5199104
Consol headsets, and turtle beach stuff is optical (but stupid)
https://linustechtips.com/topic/385049-optical-help/#findComment-5199110
@General_Led
Umm well a couple different things. Speaker set up and I'm trying to get a deal for a dac/amp combo, however it only accepts optical or coaxial.
https://linustechtips.com/topic/385049-optical-help/#findComment-5199329
Weerrll, I would suggest that if you don't have optical out already, you should get a USB DAC. Spending more money and putting more components in the pipeline is probably not optimal. You could certainly get an Asus Xonar with s/pdif but that seems silly.
https://linustechtips.com/topic/385049-optical-help/#findComment-5199695
