when do when a wu will be complete ?
Go to solution Solved by blackadder,
so im a noob and just started an hour ago and im running a 4690k at 4.1 ghz and a gtx 970, and so far the eta for wu completion keps bouncing around but where is says gpu and cpu it has a progress bar, so far the cpu is at 17% and the gpu says 21.5% so when do i know its done ? will it be done when both bars are at 100% ?
CPU and GPU works on different projects so when either one of them 100% they have completed the work unit
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
https://linustechtips.com/topic/384435-when-do-when-a-wu-will-be-complete/
so basically im working on two separate wu ?
and a car thread !
oh ok i see i can click on my gpu and my cpu and theres two tabs ok i undertand now thanks
and a car thread !
yes, well most the time you are. you can get the same project or get  several of the same project  in a row. it should tell you a little bit about the project, you may have to open the chome app to see. its pretty cool stuff, i highly recommend looking up what your pc is working on.
ya i looked a bit into and its pretty cool. although i have one more question. when i press stop folding and shut my pc down for the night and turn it back on tomo and start foding will it continue where it left off ?
and a car thread !
almost, it saves periodically, so you may be a few minutes behind. there should be a setting for it, not sure where it is.
i dont see any settings besides low med and high
another note dam didnt realise we are ranked 22 on the f@h leaderboards
and a car thread !
hmm, i have been doing boinc lately, i have to check f@H setting see if i find anything. I know 22 is crazy, we have had tons of active members after they released the video on it. Also we are kinda a younger team too so, that makes it more impressive. Also keep a eye on temps, folding is very stressful, we all get stressed from math.
temps are good my cpu is sitting at a nice 55-60 degrees and my gpu is at a steady 70 degrees as always and at 50% FAN SPEED, IT REALLY LIKES THAT ZONE WHETHER im gaming or folding it sticks to that 70 degree at 50% :/
and a car thread !
srry caps lock
and a car thread !
and dam my gpu kicks my cpu`s a** in folding
and a car thread !
yup, everything looks cool. I hit 68c with fan speed at 68% with g1 gigabyte. Glhf folding.
dam why so hot ? or do you just have a steepo fan curve ?
and a car thread !
what 970 do you have? Mine is oced and my room can be 85 f in the summer :(. I have the stock fan curve, never tried the bios mod to get it to do 0 rpm. When i play games it hovers around 63c. I have it clocked to 1500 on boost clock with 87mv added.
I have the strix. When oc'ed it to boost to 1556 mhz on stock voltage so it stays the same temp either way for me
and a car thread !
