Hello everyone,
my plan is this:
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  (€71.90 @ Caseking)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (€34.50 @ Amazon Deutschland)
Motherboard: Asus Z97-P ATX LGA1150 Motherboard  (€135.02 @ Amazon Deutschland)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory  (€61.53 @ Amazon Deutschland)
Storage: Crucial BX100 250GB 2.5" Solid State Drive  (€88.89 @ Amazon Deutschland)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  (€101.20 @ Amazon Deutschland)
Power Supply: be quiet! 530W 80+ Bronze Certified Semi-Modular ATX Power Supply  (€80.90 @ Amazon Deutschland)
Total: €573.94
Generated by PCPartPicker 2015-06-11 00:46 CEST+0200
it will actually cost me only 450 € cause i will buy it on mind factory.de like everybody else in germany
then i will crank up the cpu to over  4 ghz
next month i want to add asus strix 970 or msi gaming 4g 970 for about 350€
and the month after that i will add a 4790 k or not k edition and replace the cpu
then i plan to add 8gb ram for 50€ and add 1tb hard drive for 50€
i plan to grab a deathadder croma and a cherry mx keyboard..
but i don't know which display to get, cause i play a lot of counterstrike and on a 60Hz display it really drives me crazy looking quickly up and down, its like the picture is cut in half...i also want to play pitcher on Ultra
should i get a 120z/144Hz display or one with vsync? i want a cheap 24" 1080p one if possible ..
also anything i should change?
thx
https://linustechtips.com/topic/384375-need-some-help-choosing/
If I were you, just get the 4790K to begin with and don't get the G3258.
CPU i5 3570k MOBO Asus Maximus Gene V GPU Asus DCUII 670 CASE Corsair 350D (windowless) SSD Crucial M550 256GB msata CPU COOLER Noctua NH-D14 RAM Corsair XMS3 8GB 1600mhz PSU Corsair AX750 Display Asus PB287Q 4K (my review on it http://linustechtips.com/main/topic/380533-journey-into-4k-goodness-asus-pb287q-review/) & Asus VH236H 1080P
Keyboard Logitech G710+ MX Brown Mouse Logitech G502 (my review on it http://linustechtips.com/main/topic/299464-logitech-g502/ )
Proud owner of a BlackBerry Q10.
https://linustechtips.com/topic/384375-need-some-help-choosing/#findComment-5189883
Build looks fine. You won't find a cheap high-refresh rate monitor : / I have an ASUS VG248. Worth every penny. The amount of adjustment in monitor position and image quality is just awesome. You might consider investing in a monitor before the high powered hardware because counter strike isn't a super intensely demanding game.
https://linustechtips.com/topic/384375-need-some-help-choosing/#findComment-5190869
