Final Build! (help please)
How much would that run me? How important is g sync for gaming? I've researched it but am more concerned with higher Hz than either Resolution or G sync. Is that a poor mindset?
Also, that Monitor is 60 Hz, not 144. I thought you did it at 2k and was about to flip out
Yet another suggestion for a 800 W. I have for sure been convinced
I do video editing. Also, this will likely be what I am using for 3-5 years. Would this change your recommendation for the i5?
The g sync display would cost around 750 dollars for the display alone. So, that would total to around 2450 dollars for the whole bulid. G sync helps eliminate tearing which makes gaming smoother. About the i7, it depends on wether you do heavy video editing or not, the i5 overclocked can handle moderate to heavy editing loads, but would be slow for very long or complex video projects.
Here is the bulid with a g sync monitor
Generated by PCPartPicker 2015-06-10 08:38 EDT-0400
