One power cable or two?
Solved by W-L,
Asus GTX 980 Matrix Platinum video card.
Cooler Master v850 80+ gold.
The pcie power cables that came with the psu have a double 6+2 tip. Can I just use one cable for both 8 pin power inputs or do I need two separate cables? Or do I use a "Y" splitter cable?
Thanks!
Welcome to the Forums!
You can use the cable that has two 6+2pins PCI-E to power that card it shouldn't be a problem.
