So after every reboot of my work PC I sit at around 70% memory usage with nothing really open. Do you guys know what could be causing this? This PC has 8GB of ram but can only utilize 6.9GB of it due to iGPU. But I still think sitting at that high of a usage at idle is a lot.
post-8890-0-05609800-1433876048_thumb.jp
ACS Systems - Jason Neal
My "Danger Den" PC: i7-4960x @ 4.5Ghz, ASUS X79 Deluxe, 3x GTX Titan Black, 6x m4 512GB, 64GB Corsair DDR3-2400, Corsair AX1500i
Black Beauty Workstation/LAN PC: i5-4570 @ 3.79 GHz, ASRock Z87E-ITX, XFX Double D R9-280 (Non-X), GSkill 8GB DDR3-2400
https://linustechtips.com/topic/383621-another-problem-thats-stumping-me/
post-8890-0-71628100-1433876340_thumb.jp
you might have something starting with your computer.
try stopping any startup's you know you don't need.
also try running some malware scan's as you might have some spyware/adware on your pc
try something like JRT, AdwCleaner or malwarebytes
Win 10 Pro 64bit| Intel i5-4670k| Corsair H100i| ASUS Maximus VI GENE| 2x8GB PC3-14900 Corsair Vengeance Pro Red| MSI GeForce GTX 1070 | SanDisk 240GB Extreme Pro SSD| WD 3TB Red | WD Black 3tb | Corsair Obsidian 350D| Corsair AX760 | Dust |
Unused memory is wasted memory, and in order to speed your system up, Windows makes use of the free space to store data which makes your system run faster. When called for, this data is then retrieved from RAM instead of the much-slower HDD. Should you run an application (including games) that require this memory space, then the management routine relinquishes that space and it is made available for your application.
It won't show up in the processes
Kaspersky didn't show anything with it's Full scan.
Yeah I know it's not about that, I have 1.5GB cached and 5+ GB in use by processes.
antivirus software can only find what they are programed to find and sadly will not know every threat out there
so it might still be worth giving them a try.
Firefox 500mb How many tabs is that. :o
5 tabs. Firefox has always been a pain but it isn't the main problem.
Update: Malwarebytes has 0 detected objects.
svchost.exe has 2gb of committed memory... could that be a problem?
