So, on PcPartPicker i was making a build and i ran into a memory problem, I keep getting a RAM compatibility issue saying it is to big and there needs to be a certain amount of slots used. I want to use an ASUS MAXIMUS VI Hero, so how do i solve this issue? Seriously this is really bothering me.
https://linustechtips.com/topic/383593-big-problem-need-help/
I'm going to guess that you chose a set of RAM that exceeds the motherboard's maximum supported memory? 聽Or, since you mentioned slots, a set that has more sticks than the motherboard has slots.
i7-5820k 聽| 聽MSI X99S SLI-Plus 聽| 聽4x4GB HyperX 2400 DDR4 聽| 聽Sapphire Radeon R9 295X2 聽| 聽Samsung 840 EVO 1TB x2 聽| 聽Corsair AX1200i 聽| 聽Corsair H100i 聽| 聽NZXT H440 Razer
https://linustechtips.com/topic/383593-big-problem-need-help/#findComment-5179142
