I got my i7 running at stock speed.
Got push/pull fans on my h100.
My idle temps are fine: 25-30.
My prime95 temps are insanly high, after 1min it's already at 90...
Also Corsair Link doesn't work, so the fans are just spinning the same speed (fast, but not noisy).
Don't know what I can do about it?
But 90 after 1min of prime seems a bit too high...
Hope anybody can help me
https://linustechtips.com/topic/383496-i7-4770k-h100-temp-problems/
just go for pull and reseat the cpu block imo.
Appelzaadje - the Insane
Intel i7-4770K - Maximus VI Formula - Corsair Dominator GT 1866mhz - R9 290X - Xonar DGX - Samsung 840 Pro 256Gb - 3X WD1001FALS - Raven RV01 - Iiyama B2409HDS 3x - Custom water loop - Windows 10 Pro - XFX tripple monitor stand - Steelseries 4HD - Logitech G9, G19, G35 and Z5500
Make sure your voltage setting in BIOS is not adaptive, as it may draw too much power and overheat the CPU.
Desktop:
CPU: Ryzen 5 5600x  | Cooler: be quiet! Dark Rock 4 | Motherboard: Gigabyte B550 Aorus Pro AC | RAM: 2x8GB Crucial Ballistix 3200MHz | GPU: Asus GTX 1070 ROG Strix | PSU: ADATA Core Reactor 850W | Case: be quiet! Pure Base 500DX | HDD: Samsung HD502HJ 500GB | SSD: XPG M2 SX8200 Pro 512GB | SSD 2: Crucial MX500 500GB | Microphone: Blue Snowball iCE | Headphones: Corsair HS70 Wireless | Soundcard: Maya U5 5.1 | Speakers: Genius SP-HF1800A | Phone: Samsung Galaxy S10
Secondary Desktop:
CPU: Intel i7 4770k @stock | Cooler: Cooler Master Hyper 212 Evo | Motherboard: Asus Z97-PRO (Wi-Fi AC) | RAM: 2x8GB 1600MHz DDR3 | GPU: Asus GTX 1070 ROG Strix | PSU: OCZ ModXStream Pro 700W | Case: SilentiumPC Aquaris X70W | HDD: Samsung HD502HJ 500GB | SSD : Corsair Force LS 240GB
ASUS ZenBook Pro UX550VD:
CPU: i5-7300HQ | RAM: 8GB DDR4, 2400MHz | GPU: GTX 1050 + Intel HD Graphics 630 | Storage: 512GB M.2 SSD
I changed it to 'auto'. Didn't made any difference...
I also dont know, but my volt was around 1.8?
That seems a bit high for me?
This is my coretemp window after 2min of prime:
Hope this can help you ?
If it REALLY was 1.8V, then here's your problem. Set it to Static at something about 1.150V if you're stock, try 1.2V if you don't POST.
@EDIT
Wait, nono, it seems fine in CoreTemp... the hell?
Desktop:
Secondary Desktop:
@EDIT
Ah i'll check my bios once more and try lowering it to 1.150!
Thanks!
if that still didnt fix it check if u can hear the pump turning our bubbeling plenty of those h100 ive seen that the pump breaks or the liquid is to lil wich makes for bad cooling
