Hello,
I've run into a small problem that's a little annoying. I left my computer in my parents basements as I've been in the US for 7 months. Pretty constant atmosphere.
Coming home I obviously expected it to work as I left it, but that didn't happen.
I got no post. Only a Q LED for CPU, and Q code 00.
Tried reseating it. No bend pins. I've checked the PSU with a multimeter, and it's all good.
Here are the specs:
i5 4670k (was overclocked at 4400mhz)
Maximus VI Formula
G Skill F3-2133C9D-16GTX
Asus GTX 770
Corsair H100i
Cosair HX750 PSU
Evo 750 SSD
There is no visible damage. The CMOS battery is fine. Can anyone offer any suggestions?
Kind Regards,
Martin
https://linustechtips.com/topic/382340-no-post-after-storage/
I googled your issue and from the solved threads it looks like people managed to fix the issues with a bios firmware update, is that a viable option for you? http://dlcdnet.asus.com/pub/ASUS/mb/LGA1150/MAXIMUS-VI-FORMULA/MAXIMUS-VI-FORMULA-ASUS-1603_and_BIOS-updater.zip?_ga=1.11880628.1444957015.1432566576
Zalman Z9 Plus - GTX 660 TI - i5 2500k @ 4ghz - MSI 1155 Intel P67 - Corsair CMPSU-750HX - 16GB G.Skill Ripjaw 1600mhz 9-9-9-24 - Seagate ST3500413AS 500GB - Seagate ST2000DL003 2TB Backup Storage -  Old CBA to change it.
https://linustechtips.com/topic/382340-no-post-after-storage/#findComment-5164334
Clear CMOS and try booting with onboard graphics.
It could be that another component has failed in storage and is preventing the PC from posting. I would try disconnecting anything that is not essential (such as storage drives, add-in cards etc) to remove as many possible failure points as possible.
[spoiler=REDWING]  REDWING   | Custom Hard Line Water Cooling Loop   |   Intel i7-4790K @ 4.7Ghz   |   Asus Maximus VII Ranger   |   Corsair Dominator Platinum DDR3-2400 2x8GB   |   2 x Gigabyte GTX970 G1 Gaming (SLI)   |   Corsair AX860i   |   Samsung 850 Pro 512GB   |   Corsair Obsidian 750D   |   Corsair K95 RGB & M65 RGB   |   Samsung SyncMaster S27B370
Project Redwing Build Log
[spoiler=ZedNAS] 'ZedNAS' Home NAS Build   |   Intel Xeon E3 1231 v3   |   ASRock Rack E3C224D4I   |   Kingston KVR16E11/8I 2x8GB   |   Corsair HX750   |   6 x HGST Deskstar NAS 4TB 7200RPM HDD   |   Fractal Design Node 304 mITX Black   |   FreeNAS w/ PleX   |   ZFS Raid-Z2 (16TB Effective)   |
https://linustechtips.com/topic/382340-no-post-after-storage/#findComment-5164552
By the sounds of it it isn't a viable option, however there's the asus ez flashack bios option that he can try and then update from there providing it works, so try to use that option to flash your bios back a set @Coldbear.
Motherboard: MSI G45 | CPU: Intel i7 4790K | RAM: 16GB G.Skill DDR3 | SSD: 2x Samsung 840 Evo 256GB | Graphics: EVGA GTX 1080 FTW | PSU: Corsair HX650W | Cooler: Cooler Master Hyper 212 Evo | Fans: 6x Corsair SP120's | Case: NZXT H440 Razer Edition | OS: Windows 10
https://linustechtips.com/topic/382340-no-post-after-storage/#findComment-5164577
I would also suggest removing and reseating all other components. You may possibly have a single fouled contact somewhere in the system that is causing problems. You can also try swawpping out and booting with single ram sticks to ensure its not a dodgy stick of ram thats causing problems.
https://linustechtips.com/topic/382340-no-post-after-storage/#findComment-5165559
