Hello
Awsome Comunity!!!
I am having an issue with booting up my system, half the time the system boots up fine and the other half it will just stop at the windows boot screen with the POST code AE on the motherboard.  This has only started happening since I upgraded my SSD's to a RAID 0 configuration.  I just did the normal thing setting RAID in the BIOS and,  Ctrl-I for intel’s rabid storage using the on-board RAID with the ASUS Maximus VII Hero.  I did nothing extreme after that, just a fresh install of windows 8.1 and then this started to happen.  it only happens about 50% of the time which is wiered.
Any ideas what the problem might be?
Thank you in advance
https://linustechtips.com/topic/382179-help-boot-problems/
