I just switched on my PC and this pink/magenta lines appeared on the right edge of my monitor.
Anybody have any idea what's happening?
HP 15-BA021AX - 2.3GHz AMD A10-9600P processor - 4GB DDR4 RAM - 1TB 5400rpm Serial ATA hard drive - 15.6-inch screen, AMD Radeon R7 M440 2GB Graphics - Windows 10
https://linustechtips.com/topic/382174-pinkmagenta-right-edge/
I'd say the monitor is starting to go bad... what kind of monitor is it?
Acer S230HL LED Backlit LCD. It's not very latest but I purchased it just 6-8 months ago.
https://linustechtips.com/topic/382174-pinkmagenta-right-edge/#findComment-5160642
Do you have another monitor you can try to rule out any problems with the video card and cable? If it is the monitor, might be worth checking if it is still under warranty...
https://linustechtips.com/topic/382174-pinkmagenta-right-edge/#findComment-5160715
I don't have any video card, using the integrated intel graphics. Then too I'll try changing the cable or gonna ring the customer care tomorrow.
https://linustechtips.com/topic/382174-pinkmagenta-right-edge/#findComment-5160806
