Having trouble with my cpu-fans. I recentley built my first real computer, and got myself an h100i aio-cooler and two corsair SP-fans (3-pin). (The fans are connected to the motherboard with a cable splitter). Everything is working fine, except my cpu-fans are going full speed constantly. I'v tried to create custom fan-curves in the bios, in msi command-center (motherbord is MSI Z97 gaming 5), even tried corsair link, but the fans won't respond.
Anyone who can help?
https://linustechtips.com/topic/382097-cpu-fans-not-responding/
Plug them into the h100i and use corsair link. Just ensure the usb dongle is plugged in. Corsair link cant do anything with them plugged into the mother board, so see if that would work.
https://linustechtips.com/topic/382097-cpu-fans-not-responding/#findComment-5160509
Thanks Mick, I'l try it. But shurely you should be able to change the cpu fan speed through the motherboard?
Yea I control about 6 fans through the mobo. I leave the h100 fans connected to the pump though. Both of my  programs work the way I need them too. I have an asus though.
https://linustechtips.com/topic/382097-cpu-fans-not-responding/#findComment-5161706
