The question is should I go for a decent 2.1 system or a average 5.1 system for my new rig ?
Going to use it for gaming most of the time (fps and racing )
Edifier M3250
Edifier C3x
Logitech Z523
Logitech Z506
Creative sbs A550
Edifier M1550
Which is the most ideal speaker for my use
https://linustechtips.com/topic/380141-pc-speaker-model/
Edifier M3250
Edifier C3x
Logitech Z523
Logitech Z506
Creative sbs A550
Edifier M1550
Logitech Z506
Id recommend against all of those and getting a powered bookshelf speaker or a passive set with an amp if you can.
https://linustechtips.com/topic/380141-pc-speaker-model/#findComment-5135982
My preference for gaming is a headset. Speakers are a personal taste, what are you looking for? I enjoy my logitech stuff a lot.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/380141-pc-speaker-model/#findComment-5136066
Aren't average and decent pretty much the same thing?
Not quite. Not interchangeable at least.
- cover your breasts, gain some decency
- cover your breasts, gain some...averagey?? averageness??
https://linustechtips.com/topic/380141-pc-speaker-model/#findComment-5143644
i would recommend getting a 5.1, since you are gonna be watching movies and gaming. the surround sound will help whilst gaming so you can accurately pinpoint the noobs you are currently pwning! also, surround sound is AMAZING for watching movies! if you are going to go with 5.1 i would recommend the Logitech z506 (http://www.logitech.com/en-au/product/surround-sound-speakers-z506?crid=1588) because of the affordability and the quality. if you just want 2.1 or even just 2.0 i still recommend Logitech. maybe that is just me being a fanboy, (shrugs)
https://linustechtips.com/topic/380141-pc-speaker-model/#findComment-5143750
