Hello! I'm currently trying to overclock the premium G3258 (I believe that's the right model number, it's the anniversary edition)
I'm using the stock cooler and used Linus' overclocking guide and at 1.25v and 3.5 Ghtz I'm reaching 80 degrees C!
I've looked on some forums and people say that they are reaching 4.0Ghtz and are at 50 degrees! My room is at about 72 degrees F and I have great case ventilation, what's wrong? Am I doing aomething wrong? Also I'll be overclocking the i5 4770k in a minute. Any suggestions?
https://linustechtips.com/topic/379612-my-first-overclock/
Which CPU cooler do you use?
nvm, didn't read it properly
Project Pluto
i3 4170 MSI H97 PC Mate MSI R9 380 2GD5T @ 1095MHz Kingston HyperX Fury Blue 2x4gb @ 1600MhzWD 1TB Blue • be quiet! Pure Rock • NZXT S340 Black XFX TS 550w • BenQ GW2265HM
https://linustechtips.com/topic/379612-my-first-overclock/#findComment-5129674
I'm using the stock cooler and used Linus' over locking guide and at 1.25v and 3.5 Ghtz I'm reaching 80 degrees C!
I've looked on some forums and people say that they are reaching 4.0Ghtz and are at 50 degrees! My room is at about 72 degrees F and I have great case ventilation, what's wrong? Am I doing aomething wrong? Also I'll be over locking the i5 4770k in a minute. Any suggestions?
it's the stock cooler. those are designed for the stock clock speeds. once you go overclocking you ramp up the temps accordingly, and a stock cooler just isn't enough!
a good and cheap replacement cooler would be the hyper 212 evo!
https://linustechtips.com/topic/379612-my-first-overclock/#findComment-5129679
Most people use a liquid cooler, the stock cooler isn't bad but you have to look at how much you're pushing the card.
CPU i7 4790K @4.8GHz | Motherboard ASUS HERO VII Z97 | Cooler Corsair H110i GT | GPU Gigabyte G1Gaming GTX 970 SLI | PSU Corsair HX750i
RAM Corsair Vengeance Pro 16GB 1866MHz | HDD Western Digital Red 1TB | SSD HyperX Savage | Case NZXT Noctis 450 OS Windows 8.1
Keyboard Corsair K95 RGB Mouse Corsair Sabre Laser RGB | Headset Corsair H2100 Wireless 7.1
https://linustechtips.com/topic/379612-my-first-overclock/#findComment-5129680
I've heard the pentium can be overclocked to 3.5 or 3.7 are reasonable temps withy the stock cooler. It's only a dual core. And It's for a client that doesn't want to spend anymore money so I have to work with what I've got friends. Has anyone overclocked this chip?
https://linustechtips.com/topic/379612-my-first-overclock/#findComment-5129703
it might be that your CPU is just a bad overclocker then. or you could always check if the thermal paste is applied correctly. (just to make sure)
i have no experience with that CPU, tough i tried overclocking my I5 4670K with the stock cooler before and it just didn't work. it got immensly hot with just a few Mhz overclock. :(
https://linustechtips.com/topic/379612-my-first-overclock/#findComment-5129765
You need at least an after market cooler if you're going to be overclocking, I would at least say Hyper 212 evo.
https://linustechtips.com/topic/379612-my-first-overclock/#findComment-5129797
