Having an issue right now where ill be using my pc and randomly my monitor will switch and say dvi no signal as im using it. If i turn it off, then back on it comes back sometimes and it says display driver has stopped working.
Unsure if issue is my dvi cable, gpu hook up, monitor, psu, windows , dirver issue or what.
First time im gonna try is switching to a display port cable.
Ok here is windows error seems driver issue?
https://linustechtips.com/topic/379160-dvi-no-signal-issue/
could be a driver issue. Try reverting to an older driver or update the current one if you have not already.
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/379160-dvi-no-signal-issue/#findComment-5123631
If i roll back im going to lose around 20fps in witcher 3. Latest driver fixes issues in the game.
The reason i said to try rolling the driver back is because the new driver may have been what caused the dvi issue in the first place.
https://linustechtips.com/topic/379160-dvi-no-signal-issue/#findComment-5123956
The new driver is most likely causing this problem. Unfortunately you will have to rollback to the older driver and lose those 20 fps in Witcher 3 until a new update is released.
Yup it seems be the issue i used DDU clean installed same issue im rolling back now..
Good thing im switching to AMD in near month.
https://linustechtips.com/topic/379160-dvi-no-signal-issue/#findComment-5131646
