So, I've had this problem for a while where if i record a video (it records fine) and when i play it from the start, it plays the way through, but if i skip say 5 mins into the video the video will freeze and stop playing.
I have already tried, reinstalling and changing settings but nothing seems to work.
Is there anyway to fix this issue?
| Ryzen 7 3700x | 16GB Vengance @ 3200 | MSI GTX 1070Ti Gaming |
| ADATA XPG SX8000NP 256GB Nvme SSD + WD Blue 500GB SSD | 4TB WD Blue |
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/378831-obs-video-problems/
have you tried watching the video with a different media player?
https://linustechtips.com/topic/378831-obs-video-problems/#findComment-5119250
yes i have tried in VLC and MPC. It also does the same in Sony Vegas and it makes it hard to edit.
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/378831-obs-video-problems/#findComment-5119256
and this doesnt happen with video files that you have not recorded with OBS?
https://linustechtips.com/topic/378831-obs-video-problems/#findComment-5119266
Yes however if i compress or convert the file to plays fine.
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/378831-obs-video-problems/#findComment-5119274
What are you recording that you use OBS? The only thing I would recommend OBS for is streaming, not recording.
https://linustechtips.com/topic/378831-obs-video-problems/#findComment-5119290
Games and desktop, it worked fine for 3 months and then this happened.
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/378831-obs-video-problems/#findComment-5119297
Do you want to have a new recorder that won't impact performance as much? I have had problems with OBS also, that's why I stopped using it to record.
https://linustechtips.com/topic/378831-obs-video-problems/#findComment-5119307
well i would like to but OBS is free and it has Nvidia NVENC which allows me to record.
EDIT: Otherwise i would record at like 11 FPS
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/378831-obs-video-problems/#findComment-5119322
I record using OBS and have no issues. OBS is fine for recording, just make sure it's set up properly for recording.
http://linustechtips.com/main/topic/185565-guide-recording-gameplay-with-obs/
Project Tomahawk:
CPU: Intel Core i7 4790k
Motherboard: Asus Maximus VII Hero
CPU Cooler: Corsair H100i
Memory: 16GB Kingston HyperX Fury 1866 Mhz
GPU: Asus Strix RX 480
PSU: Corsair RM1000
Storage: 2x Western Digital 2TB Enterprise + 240GB Crucial M500 SSD
Case: Corsair Air 540
Additional: Cablemod C-Series black/red kit, SP120, AF140 and AF140 w/ red LED's all around
Project Frankenstein:
CPU: AMD FX 6100
Motherboard: MSI 970 SLI Krait Edition
CPU Cooler: Cooler Master Hyper 212 EVO
Memory: 8GB G.Skill Ripjaws X 1866 Mhz
GPU: MSI R9 280 3G Twin Frozr
PSU: Seasonic M12II EVO 620W
Storage: Western Digital 1TB Enterprise + 240GB Partiot Torch SSD
Case: Fractal Design Define S
Sheila (Server):
Dell R210:
CPU: Intel Xeon x3450
Memory: 12GB Crucial ECC 1600 Mhz
Storage: Seagate 3TB Constellation
Marvin (Server)
Dell R210ii
CPU: Intel Xeon E3 1230v2
Memory: 12GB Crucial ECC 1600Mhz
https://linustechtips.com/topic/378831-obs-video-problems/#findComment-5119352
My settings are fine but this just randomly happened 3 months ago.
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/378831-obs-video-problems/#findComment-5119370
And nothing changed? At all? are you recording a different game now? I would still suggest going through that guide and making sure that your settings match that.
Project Tomahawk:
PSU: Corsair RM1000
CPU: AMD FX 6100
Sheila (Server):
Dell R210:
Marvin (Server)
Dell R210ii
https://linustechtips.com/topic/378831-obs-video-problems/#findComment-5119409
I am recording all the same games, but your settings seem a bit too low quality for me because ive always been recording at 10000kb/s.
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/378831-obs-video-problems/#findComment-5119425
Well why don't you try and turn that down...
Project Tomahawk:
PSU: Corsair RM1000
CPU: AMD FX 6100
Sheila (Server):
Dell R210:
Marvin (Server)
Dell R210ii
https://linustechtips.com/topic/378831-obs-video-problems/#findComment-5119438
I have but the quality just goes to S**T and I can record at that bit rate at 60 FPS aswell.
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/378831-obs-video-problems/#findComment-5119457
1000 kb/s works fine for me and the quality looks great, I think you're letting the numbers get to your head.
Project Tomahawk:
PSU: Corsair RM1000
CPU: AMD FX 6100
Sheila (Server):
Dell R210:
Marvin (Server)
Dell R210ii
https://linustechtips.com/topic/378831-obs-video-problems/#findComment-5119474
well ill try it and see what happens.
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/378831-obs-video-problems/#findComment-5119481
It still does the same even after changing to your settings.
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/378831-obs-video-problems/#findComment-5119521
