Hi.
I need your help due to my recent expiriance while gaming with my Gaming PC.
Whenever I start playing any Game (mostly CS:GO, Smite) my Pc freezes and exits the game.
If I don't restart my Computer and start up the game again my PC crashes and goes to Blue Screen :(
My PC Specs:
CPU: I5-4690K (Not OC)
GPU: Radeon HD 7850 2Gb GDDR5
RAM: 8Gb Crucial Ballistix (2x4)
and
(Win 7 64bit)
I even reinstalled OS and this still happens..
All drivers are the newest ones...
still crashes :(
https://linustechtips.com/topic/378781-hey-need-pc-help/
There's an instability somewhere. Test your computer with only 1 stick of RAM and on onboard graphics. When I got that once my motherboard was causing instability somehow. Clearing the CMOS might fix it as well.
https://linustechtips.com/topic/378781-hey-need-pc-help/#findComment-5118550
Hi.
My PC Specs:
and
(Win 7 64bit)
still crashes :(
Update you motherboards bios, if you PC is new, chances are that your bios doesnt fully support that CPU and must be updated.
You didnt mentions your motherboard in the original post.
Welcome to LTT
Main rig. Updated :D CPU: FX8350 @stock Cooler: Corsair h110 Motherboard: Ga-990fxa-ud5 Memory: Corsair Vengance 8Gigs 1866Mhz GPU: MSI GTX 970 SLI (blower cooler)  PSU: Cooler Master Silent pro 850w SSD: Corsair Force GT 60Gb HDD: WD 500 Caviar blue Case: Thermaltake core V71 Fan controler: NZXT Sentry
Secondary PC: CPU: i5 4670k @stock Cooler: Thermaltake NIC L/31 Motherboard: Asus Z97I-PLUS Memory: Corsair Vengance 8Gigs 2133Mhz GPU: ZOTAC GTX 780 (Titan cooler) PSU: Antec 520m Pro SSD: Corsair Force GT 60Gb HDD: WD 500 Caviar blue & WD 2TB Green Case: Thermaltake core V1
https://linustechtips.com/topic/378781-hey-need-pc-help/#findComment-5118607
Welcome to LTT
http://gyazo.com/db3e1de95994f63d911e2dbd10328d85everyting is updated ;) (sry: msi B85-G41)
https://linustechtips.com/topic/378781-hey-need-pc-help/#findComment-5118639
https://linustechtips.com/topic/378781-hey-need-pc-help/#findComment-5126638
