Title says it all, im not really planning on overclocking i think, also where does the reference cards leave there heat?
How is the airflow in your case?
Love cats and Linus. Check out linuscattips-fan-club. http://pcpartpicker.com/p/Z9QDVn and Asus ROG Swift. I love anime as well. Check out Heaven Society heaven-society. My own personal giveaway thread http://linustechtips.com/main/topic/387856-evga-geforce-gtx-970-giveaway-presented-by-grimneo/.
The reference cooler exhausts out the back whereas most non reference coolers exhaust into the case, however, both shouldn't limit your overclocking as that is more up to the quality of the silicon that made the chip than the cooler.
If you have a small case with poor airflow, use the reference cooler.
If you have a large case with good airflow, use a non reference of your choice.
If you plan on adding a second card in SLI right next to the first one (as tight as they can get), use the reference cooler.
I've built 3 PC's, but none for myself... In fact, I'm using an iMac that my dad bought for me as my desktop. Awkward...
Please don't say "SSD drive." By doing so, you are literally saying "Solid State Drive Drive" and causing my brain cells to commit suicide. The same applies to HDD (Hard Disk Drive) and PCIe (Peripheral Component Interconnect Express).
I've seen the reference Titan X (a distinction I'm happy to finally be able to make :) ) throttle due to heat. I find it hard to believe that the 980 Ti is sufficiently cut down to not suffer this too.
Post your case, and your fan setup.
Reference puts the heat out the exhaust.
Non reference puts most of the heat inside the case.
Corsair 760 white
2 intake
H00i out and rear out
Can also put a fan on the bottem of the case for direct fresh air for the gpu
Corsair 760 white
2 intake
In your case:
If you use an AIO watercooling for your CPU go with aftermarket cooler/ design.
If you aircool your cpu go with reference design.
An intake at the bottom would defintly help, but only install it if the intake is filtered ;)
Good, its a corsair 760t
2 intake
1 rear out
2 top out h00i
Can also put one on the bottem of the case for fresh air for the gpu
That is good. I have several fans as well. With a custom fan profile on the reference cooler the temps stay below 75c for me and I'm running SLI Titan X. I'm assuming the 980 Ti should be a little better for temps.
Oke thats good, i like the reference look and its better i think that the hot air from the card goes out the back and not in the case, it will keep my cpu also alot cooler. Do u also have a fan that can blow fresh air from the bottem to the titans?
Forget reference.
This is LTT. One cannot force "style over substance" values & agenda on people that actually aren't afraid to pop the lid off their electronic devices, which happens to be the most common denominator of this community. Rather than take shots at this community in every post, why not seek out like-minded individuals elsewhere?
I have an MSI 980 but temps should be similar with Ti. Obviously it depends a lot on ambient temperature, fan RPM and so on. Anyway, I have a fractal design case, name escapes me but I took out all the drive cages in front (only the 5.5 bays left on the very top), 2 intakes, one out the top and out the back, all 140mm. I air cool the CPU, it gets a bit hot under 100% (actually hits 100 in prime95 extreme test), but under gaming it's around 70 or so. Anyway, with the fans around 300 RPM ambient case temperature is 27-28C with the room at 22 or so. Under load it goes up to 32-34 at times. I haven't used a reference cooler for a while, only one I have is the GTX 260 and case temps aren't that much lower IIRC. This tells me most of the heat is from the CPU. Honestly I'll get an MSI 980 Ti since the thing is dead silent even under 100% load (temps are also low, 65-70 in games).
So u mean non reference msi 980 ti?
I mean i have now 2 msi 660 ti pe and my cpu is ar idle between 25-30C so thats still pretty cool if u consider i have to cards in sli pushing air to the h100i
Reference is great for SLI and small builds. That's it.
You'll have much better results cooling an overclocked chip/vrams with a non-reference solution.
Intel i7 7700K | MSI Z270 Gaming M3 | MSI GTX 1070 Gaming X| Corsair Vengeance LPX 2x8GB DDR4 3000Mhz Samsung EVO 850 250GB | WD Blue 1TB | Corsair CS650M | Thermalright Macho Rev. A | NZXT S340
CM Storm Quickfire TK [MX Blues] | Zowie FK1 |  Kingston HyperX Cloud
reference card for me. I've an msi reference card on order
Gaming PC: • AMD Ryzen 7 3900x • 16gb Corsair Vengeance RGB Pro 3200mhz • Founders Edition 2080ti • 2x Crucial 1tb nvme ssd • NZXT H1• Logitech G915TKL • Logitech G Pro • Asus ROG XG32VQ • SteelSeries Arctis Pro Wireless
Laptop: MacBook Pro M1 512gb
Why did u got a reference card over non reference if i may ask?
for one I prefer the looks of a reference card.
and in many cases non reference cards can make the rest of you components hot as the hot air is fed into the case.
as I go for a positive airflow setup a non reference could warm everything else up (linus did a video on it recentky)
plus a reference card is £50 cheaper than the non reference cards I've seen so far. thats a 10% saving!
Yeah that was my thought exactly, i guess im gonna order 1 to haha, can u link me that video of linus perhaps?
Little off topic, but do you think a 860w platinum supply is enough for 980ti reference SLI?
Yeah its enough, 1 980 uses 250w at full power so 2 is 500w and then u got 360w left for the rest
i am going to get a 980 TI for my new upcoming build, i will start with one GFX card and then after a few months get another 980 TI, would it be best to go with reference, or will the aftermarket coolers (will go with MSI or Gigabyte) also work fine in SLI?
If you have 3 slot spacing and plenty of air, the after market ones will work just fine.
Heck I ran a CF of R9 290x with after market in an 800D case, (POS has just 1 140mm intake) was doing just fine. Granted everything else will heat up because of this, with reference you do dump a lot of heat out of the case.
"Hope, what a concept." - Deunan Knute
Having never tried SLI before, can you get connectors that can connect two cards without a card in the gab?
The Motherboard i am planning on is Asus Z97 PRO GAMER ATX LGA1150.
The case i am planning on getting is Noctis 450, so Air Cooling should be fine, i will however go full water cooling within the year, would it be easier to get water-cooling blocks for reference or aftermarket cards?
https://youtu.be/nAKyh-qqQCw
there you go :)
