hi there folks,
I am in the proces of upgrading/changing my current ATX system to an ITX system.
Now ive already ordered a new processor (4570) and am looking for a good motherboard.
Currently i am using a Hyperx Cloud headset in combo with a asus DG.
Since there is simply no room for this card in my next build, i will have to look for an alternative.
Or do you guys know an itx motherboard that has a decent enough audio chip?
Reviews of the Hyperx Cloud suggest that you should pair it with some kind of soundcard/dac amp.
do you guys have any suggestions, i am kind off at a budget ;)
been looking at the Fiio E10K, but it's price is quite steep for me,
so will it be worth it?
love to hear from you guys!
Marinus
https://linustechtips.com/topic/378117-help-with-audio/
Fiio E10K is about as cheap as I would go, but then I wouldn't buy a dac/amp for gaming headphones. Realtek alc892 is decent. https://www.alternate.nl/ASRock/H97M-ITX-ac-socket-1150-moederbord/html/product/1141505?tk=7&lk=9435
this has realtek alc1150 which is about as good as you get. https://www.alternate.nl/ASRock/Z97E-ITX-ac-socket-1150-moederbord/html/product/1141498?tk=7&lk=9435
https://linustechtips.com/topic/378117-help-with-audio/#findComment-5109976
yeah well, its kinda half a gaming headset, it's a rebranded qpad headphone, with a mic glued to it, i believe it's a 60 ohm one.
i am now even more in doubt, do i go for the motherboard i was originaly going for: http://tweakers.net/pricewatch/385582/asus-h97i-plus.html, see how that handels the audio,
and then probably need another solution,
or am i going to take the risk on realtek, get a more expensive one like: http://tweakers.net/pricewatch/379680/msi-b85i-gaming.html, sollely for the audio chip, even tough the connector layout sucks and the 25$ price increase
or do you guys have any other suggestions?
https://linustechtips.com/topic/378117-help-with-audio/#findComment-5110314
Realtek makes very competent onboard audio solutions. I would even say that many of their chips are better than the stuff that asus puts into its supremeFX chips. I would stick with the motherboard that you have already chosen. 60 ohms is not that much, and regardless, the impedance has almost nothing to do with how hard a given headphone is to drive. You should be totally fine with the headset that you have. I don't think you'll need anything like the fiio E10k or anything of the sort. You should be just fine with the first motherboard!
Hey! New SIgnature!
I'm supposedly a person on the Internet, but you'll never know if I'm human or not ;)
https://linustechtips.com/topic/378117-help-with-audio/#findComment-5113221
first, let me thank you for your reply, i really appriciate it,
ok, so you think the alc 887 is good enough, do you think i will hear any difference with the alc 1150?
because i am now at a point where i can get a msi one with 1150 and audio boost (the z87 i gaming) for the same price as the asus h97iplus, (which layout i do heavily prefer over the msi's connector's on the top side)
https://linustechtips.com/topic/378117-help-with-audio/#findComment-5115590
I think that the port layout is going to be more important to you. If anything, I would say that the different Realtek chips have different featured rather than different sound.
Hey! New SIgnature!
https://linustechtips.com/topic/378117-help-with-audio/#findComment-5115639
ive just found the perfect bord for me: msi z97i ack
it has the looks, the layout and the alc1150 sound chip, in combo
with some kind of msi chip. reviews say its a great sound card/chip,
only point is its steep price,
so i will try to look for it on ebay
and/or in discount.
ty very much for your help, i really appriciate it!
https://linustechtips.com/topic/378117-help-with-audio/#findComment-5115849
