max vcore voltage
Go to solution Solved by Lays,
Vccin use up to 2.2 max, 2.1v or less for 24/7, 2.2 for like benchmarking.
V core you're good up to like 1.4 for 24/7 use, although higher is fine for benchmarking.
You may be bsoding from not enough vccin, set to like 2.05v and see what that gets you.
Hey guys i got a i7 5930k and am wondering what is the max vcore voltage and input voltage i can set it to.
I have 2 480 rads cooling my cpu and am currently at 4.5 ghz at 1.34 vcore volts with temps of 60C.
I would like to get it to 4.6ghz but curently BSOD at 1.37 vcore volts and 1.92 input volts.
https://linustechtips.com/topic/377857-max-vcore-voltage/
https://linustechtips.com/topic/377857-max-vcore-voltage/#findComment-5106665
Ill try this since lowering the voltage didnt work.
https://linustechtips.com/topic/377857-max-vcore-voltage/#findComment-5106691
You can push a bit more than 2.2 vccin, but I wouldn't recommend it without sub ambient cooling. 2-2.1 should be good.
https://linustechtips.com/topic/377857-max-vcore-voltage/#findComment-5106699
