I plan on sli my gtx 980 and want more air coming into the case so I'll be adding x3 NF-P12 as intake on the front,x1 NF-A14 as intake on the back and x2 NF-A14 as exhaust pushing through my h110i on the top.
Practically just like that if you reverse the back as intake.
What you think?
https://linustechtips.com/topic/377677-air-540-fans-setup/
I'd say airflow fans in the front and rear, then static pressure on the radiator, front as intakes, the rest as exhausts is a good setup for that case.
https://linustechtips.com/topic/377677-air-540-fans-setup/#findComment-5104488
This is my setup in the same case. Works fine for single card. I wouldn't do intake on both front and back though, it would actually hurt the GPU cooling. Upping the speed on the front helps much more.
Very blurry phone pics.
Tips on building in the case: use 120mm fans if you want to be able to fit a rad in the front or top. I couldn't fit 2 140mm fans in the top bc of the AIO.
I don't do signatures.
https://linustechtips.com/topic/377677-air-540-fans-setup/#findComment-5104534
