I would personally wait for amd and nvidia to release their new cards (couple of weeks now), as it could have compelling options at the price point you are looking at, or there could be price drops on the gpu you are looking at. Some single gpu options may become available removing any issues relating to crossfire that you may encounter.
Also I have not heard that PSU brand before, so unless you have used them before, I would be wary
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/377498-1600-build-please-help/#findComment-5102233
http://pcpartpicker.com/p/ZBFq8dDon't spend $430 on that monitor. It's not even an IPS. Personally 1440p 144hz would be better for gaming. I can find a red keyboard unless you want a black/red/blue which would be pretty sick.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/377498-1600-build-please-help/#findComment-5102317
That gpu is slower...
Lets all ripperoni in pepperoni
https://linustechtips.com/topic/377498-1600-build-please-help/#findComment-5102328
I understand. That's also 2 GPUs in one.
@CoolaxGaming put it this way. SLI 980s vs 295x2. With directx12 having the ability to combine VRAM.. It's pretty obvious what's gonna be better for the future. Man two Titan Xs with 24gbs of VRAM.. Who would need to use that..
https://linustechtips.com/topic/377498-1600-build-please-help/#findComment-5102345
What if the guy wont sli in future?
Anyways the 980 is overpriced
https://linustechtips.com/topic/377498-1600-build-please-help/#findComment-5102373
I'd personally wait for the TI. It may drop the price $100 plus the 980ti from "leaked" specs is like a TitanX with 6gbs of VRAM.
https://linustechtips.com/topic/377498-1600-build-please-help/#findComment-5102455
I think this is a good build, I would personally change to the Gigabyte Gaming 7 and perhaps the RAM is expensive for what it is but otherwise excellent
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/377498-1600-build-please-help/#findComment-5102531
I won't be SLIing in he future unless in 5 years my gpu alone won't be able to run games well.
Yours Sincerely,
The Beast,
Sean Mullen
https://linustechtips.com/topic/377498-1600-build-please-help/#findComment-5102610
Then use this build -
PCPartPicker part list: http://pcpartpicker.com/p/3KRyrH
Price breakdown by merchant: http://pcpartpicker.com/p/3KRyrH/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.99 @ SuperBiiz)
CPU Cooler: Corsair H110i GT 113.0 CFM Liquid CPU Cooler  ($119.99 @ Newegg)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($139.99 @ SuperBiiz)
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-2400 Memory  ($104.99 @ Newegg)
Storage: OCZ Vector 180 240GB 2.5" Solid State Drive  ($134.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($48.75 @ OutletPC)
Video Card: Sapphire Radeon R9 295X2 8GB Video Card  ($556.39 @ Newegg)
Case: Corsair 780T ATX Full Tower Case  ($159.99 @ Newegg)
Power Supply: Corsair 750W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($109.99 @ Newegg)
Total: $1605.07
Generated by PCPartPicker 2015-05-31 17:09 EDT-0400
https://linustechtips.com/topic/377498-1600-build-please-help/#findComment-5102889
Total: $1605.07
I need to include a monitor in the build
Yours Sincerely,
The Beast,
Sean Mullen
https://linustechtips.com/topic/377498-1600-build-please-help/#findComment-5103054
The motherboard does not support SLI or Crossfire.
The psu is likely not of good quality. Hard to say because I cannot find a single independent professional review. EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply would be a much better choice.
https://linustechtips.com/topic/377498-1600-build-please-help/#findComment-5103517
