3570k Overlock Temps
Go to solution Solved by DildorTheDecent,
That might be it.... now the hassle to remove the backplate
Hopefully that does it. I think it should.
I am overclocking a 3570k and trying to keep a decent temperature but under full load prime95 small fft, the temperature gets to 89c with 24c ambient. The cpu is at 4Ghz with 1.176v on a h100i. I reapplied thermal paste 4 times and still the same temperatures. I checked if the backplate is loose and it was on tight. I added pressure to the cpu block while it is doing a stress tested and it dropped 10 degrees(~75c). Did I attach the block wrong or is the unit not good?
https://linustechtips.com/topic/376801-3570k-overlock-temps/
The Hydro sreies have some finicky mounting. Make sure that the backplate is installed correctly and that it is tightened down good.
https://linustechtips.com/topic/376801-3570k-overlock-temps/#findComment-5094308
https://linustechtips.com/topic/376801-3570k-overlock-temps/#findComment-5094324
