hey guys. I know its a lot to ask for, but is it possible for me to get a custom water loop for under 200 bucks? i only need cpu cooling on my 4690k. also, the coolant needs to be red. i will be working inside the NZXT H440. if you need other specs check my profile. thanks a lot everyone
https://linustechtips.com/topic/376322-sub-200-cooling/
well there are EK and XSPC kits for about $250
but you should probably just get an AiO since thats more than enough
https://linustechtips.com/topic/376322-sub-200-cooling/#findComment-5088802
If you only need the cpu cooled why not just get an aio cooler?
NZXT Kraken X61-$130
if you would like to expand watercooling to graphics card in future
Swifttech H220-X-$15
thanks but i am looking for custom water loop. it all about looks for my computer since i dont game.
https://linustechtips.com/topic/376322-sub-200-cooling/#findComment-5089020
well then save up until you can afford a cheap WC kit from ek or xspc
dont cheap out on a swifted aio, seen lots of people have problems with those
https://linustechtips.com/topic/376322-sub-200-cooling/#findComment-5089058
