I have the same motherboard, mine has 4 fan slots. If you cant find it go into eco manager (or whatever its called) and itll show where there.
best of luck :)
- ethan
i checked and there are only SYSFAN1, SYSFAN2, SYSFAN3, CPUFAN1, CPUFAN2, I just put one of htem in CPUFAN2 and it seems to work.
https://linustechtips.com/topic/375334-s340-case-fans/#findComment-5076865
yep thats what i do, usally i put my (if youre looking into your computer) the top left one just beaucse usually itll be the better fan
https://linustechtips.com/topic/375334-s340-case-fans/#findComment-5079249
