Need help installing new replacement HDD
Go to solution Solved by Jarsky,
You shouldnt need to download any drivers before installing Windows these days.
The only drivers you may need is the network driver, if you have a very cheap low-brand motherboard, or an old motherboard (over 5 years old) which may use a network chipset that isnt common.
Your graphics and other motherboard drivers can be downloaded directly on the computer once you've established a network connection :)
Nope you don't need a Processor drivers, these are already included in Windows.
Basically, once you've installed Windows - go into Device Manager, and see what has a conflict and get those.
Other than that typically Audio & Graphics (and some boards raid controller drivers) will be the only generic drivers you need to replace with ones from the vendors website.
Hi, I bought a new HDD for my PC because my older one is faulty and it should arrive in 2-3 days and I'd like a bit more knowledge on what to do when it arrives. It will be the only drive in the computer.
So, I've already backed up important files and things, and I know that I will need to remove the drive from the cage by unscrewing it on either side, as well as unplug the cables. Then in comes the new drive, plug it in, screw it into place... but then what? I know I'll need to reinstall windows, I've got the CD but I heard that you need to format the drive, and that's what I need help with. How do I do that? Or is it even necessary? If I need to download something onto a memory stick or something, could I have a link to it and instructions as to what to do? Yeah, I'm a bit confused by this; it's my first time doing pretty much anything with hard drives.
Thanks.
https://linustechtips.com/topic/374424-need-help-installing-new-replacement-hdd/
You can do the formatting and such when installing windows.
As @TheKDub said, Windows wil format the new HDD for you when you install it.
You will also need to download and install up to date drivers for your hardware. I suggest you download those before removing your old HDD and put them on a USB drive for easy installation on the new OS. This will most likely just be your motheboard and graphics card drivers (but any other hardware such as sound cards will have their own drivers), all of which should be easy to download from the manufacturers website.
"PSU brands are meaningless, look up the OEM."
Ok, so just to make sure I understand: I need to download drivers for my graphics card and motherboard, put them on a memory stick and after Windows is installed, install them, yes? Will I need any drivers for the new HDD too or should I be fine without having to download any? Will I need any drivers for my processor too or is that not necessary?
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
