wait windows is $15?!?!?!
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
https://linustechtips.com/topic/374354-1100-build-help/#findComment-5063553
You can get a Z97 board for that price
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/374354-1100-build-help/#findComment-5063784
Gaming you say? Swap the Xeon with i5 4690k and Z97 board :D And Overclock that bad boy up!
CPU: i7 5820K Motherboard: MSI x99A SLI PLUS RAM: Corsair Vengeance DDR4 2800mHz (4x4gb) GPU: MSI GeForce  GTX 980Ti Case: NZXT S340 Storage: 840 Evo 120gb and WD Blue 1TB  PSU: EVGA SuperNOVA G2 850W CPU Cooler: be quiet! Dark Rock 3
GTX 980 Ti (reference card) High Idle temps solution -
https://linustechtips.com/topic/374354-1100-build-help/#findComment-5063833
Well there are multiple things
PSU is expensive for what it is
16GB RAM minimum for editing really, if he is going to be even half-serious
Z97 board is in reach
https://linustechtips.com/topic/374354-1100-build-help/#findComment-5064168
i would like a high quality PSU, and its really a x series seasonic PSU for $30 less
i will upgrade to 16 gigs later, hence the 1 8 gig stick
it probably is but i want to keep the red/black color scheme and have an asus board
https://linustechtips.com/topic/374354-1100-build-help/#findComment-5064189
There are Z97 red/black boards, such as the Gigabyte Z97X-SLI, but if you want Asus then go ahead (the SLI has a brown PCB unfortunately though)
http://pcpartpicker.com/part/evga-power-supply-110b20750vr
That is an excellent PSU for the price, high quality indeed
https://linustechtips.com/topic/374354-1100-build-help/#findComment-5064214
http://pcpartpicker.com/p/V2YXqs
how does it look?
i am most skeptical about the PSU and video card, iv read mixed reviews on them
constructive critisizm is always appreciated thanks!
http://pcpartpicker.com/p/jPR43CHope you didnt order it yet.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/374354-1100-build-help/#findComment-5064749
No monitor
https://linustechtips.com/topic/374354-1100-build-help/#findComment-5064759
No monitor
http://pcpartpicker.com/p/4nZQvK$16 more with windows and excluding any mail in rebates. His is at $1185 without Mail-In's
https://linustechtips.com/topic/374354-1100-build-help/#findComment-5064815
a few things:
1: i have already ordered it
2: i need hyper threading because (if you had read the above posts) i will be doing some editing/rendering
3:i also said i wanted an asus board
4: i went for the define r5 because the define S is not in stock
5: the hard drive you chose is $16 more
6: i want to game at 1440p
Edited by Mandrew
https://linustechtips.com/topic/374354-1100-build-help/#findComment-5065334
a few things:
1. Both will work fine, even for rendering and editing, a bunch of youtubers use 4690ks
2. Why ASUS? Why h97? Misewell get a Z97. Nothing special about ASUS.
3: I just chose the case because why not.. Doesn't really matter which one you get.
4. Good luck gaming at 1440p on a 290, I wish you luck on that.
https://linustechtips.com/topic/374354-1100-build-help/#findComment-5065366
1:z97 would be wasted because its a xeon (u can't overclock it)
2:im not playing very GPU intensive games(tf2, gmod) and if i were to play harder to run games in the future i can add a second 290
https://linustechtips.com/topic/374354-1100-build-help/#findComment-5065413
Still at 1440p a 290 in crossfire will still be pushing it...
https://linustechtips.com/topic/374354-1100-build-help/#findComment-5065427
