Long story short, a few days ago, I decided to format my hard drive, as I planned on doing so with both, my hard drive and SSD. The SSD has yet to be formatted. My hard drive, on the other hand, was formatted. However, after doing so, I am now facing a problem. Before I format my SSD, I want to recover some files using File History as I am running Windows 8.1. I want to recover a few important files and folders, which I was able to do before I formatted my HDD.
The problem, though, is that for some reason, while I am able to access my HDD through My Computer and view the files and folders currently on there, when I go to file history to recover some files from my SSD or even my file history settings, it tells me that my HDD is disconnected. I have tried trouble shooting, but nothing seems to work. Does anyone know how I can fix this problem?
Any and all answers of use will be appreciated.
Thank you.
post-120037-0-44193000-1432635813_thumb.
post-120037-0-43195000-1432635978_thumb.
https://linustechtips.com/topic/374051-hard-drive-disconnected/
Thank you.
Hey Chompus,
Are you trying to recover files that were on the HDD that was formatted, or files from the SSD? Or the problem is that you cannot set the HDD itself as a destination for storing the backups?
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/374051-hard-drive-disconnected/#findComment-5060343
Hey Chompus,
Captain_WD.
The files and folders were on my desktop, so my SSD.
https://linustechtips.com/topic/374051-hard-drive-disconnected/#findComment-5060608
Thats an odd error, I wonder if its not picking up the GUID of the drive properly. Have you moved it to a different SATA port or anything at all?
Perhaps try removing it from Device Manager (right click Uninstall) then scan for changes, to let it rescan the bus and re-add the drive - then give it another try
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/374051-hard-drive-disconnected/#findComment-5062963
