partion problem
Solved by Jarsky,
What have you done to these disks?
Disk 6 looks like an OEM install, but you've deleted the main data partition that Windows would be on.
So if you just want that to be an empty disk, then just right click on each partition and delete them. This will give you a full Unallocated space - which you can right click and format and assign a drive a letter. They're all recovery and boot partitions.
Disk 7 you can delete the OEM Partition.
In order to use that space on Disk 7 and Disk 5 though you would need something like Partition Magic, to expand your partition across the unallocated space.
