Lol of course it will. If each game required a different GPU the gaming industry would be on its arse
If you want my attention, quote my post or I will not see it. I ignore builds that do not use PCPartPicker.
If I have solved/answered your question, please press "mark solved" to make it easier for the rest of the community find the answer
What would make you ask this question?
I meant as a minimum, basically if the 8800 is the minimum GPU for a PC, is the 960 the same or better enough to run it?
You're looking at it the wrong way. The games aren't specifically made to run on those specific cards.
Each card tier has different performance, and the 960 will run anything better than the 8800.
i had the 9800gt (rebranded 8800gt) and it cant run those games for shit, but a 960 will do well
9800X3D - NH-D15S - MSI X670E  -  32GB 6000MHz CL30 - RTX 3080 FTW3 - 970evo 1TB - 980pro 1TB - 970evo 1TB - 970evo+ 2TB -  970evo+ 2TB - 850evo 250GB - WDblack 1TB - WDblue 3TB - HX850i -  27GR95QE-B.AEU - 28MQ780-B - 27GP850-B - 27GL850 - Meshify 2
I think your getting confused by the naming scheme.. the 8800 is over 10 years old the 960 is new.. the 960 is WAY better.
I don'T PreSS caPs.. I juST Hit THe keYboARd so HarD iT CriTs :P
Quote or @dzzope to get my attention..
You can't even start comparing the two, as the 8800 GT is so old. What game are you thinking of?
In any case, GTX 960 is very capable.
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
i bought a 8800 in 2007, in todays terms its would be equal to poop, the 960 is light years better its like comparing a ps2 to a xbox one.
cpu:i7-4770k    gpu: msi reference r9 290x  liquid cooled with h55 and hg10 a1     motherboard:z97x gaming 5   ram:gskill sniper 8 gb
960 is better, end of story
My Main PC:
CPUi5 3570k CPU Cooler: Cooler Master Hyper T4 Motherboard: Asus p8z77-v pro  RAM: Crucial Balistic 2x4gb  GPU: Two PNY GTX 680's in SLI Case: Some rando Antec one  PSU: Thermaltake 1000w  Display: HP Elite Display 321i 23''  Storage: Samsung 840 Evo 128gb, Seagate Barracuda 1tb
Thank god for DirectX...
Trust me, the 960 takes gt 8800 out to the woods and kills it with a shotgun.
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
