My first PC build
Please demonstrates me how the Sapphire Radeon R9 280X Dual-X 3GB Video Card is better than MSI GeForce GTX 960 4GB!!!
The issue isn't so much that the 280x is "better" than the 960, the issue is that it costs less for very similar performance. I think you would do well to look into the 280 (non x version) because it's significantly cheaper than both the 280x and the 960. You would also do better to upgrade your motherboard to one that can support SLI/Crossfire and four memory slots.
That motherboard also looks like a micro ATX with very limited PCI slots. You have no USB 3.0. You're paying nearly $250-300 more for an over glorified console in a pretty large case. If you're going this route, at least look into a mini-itx board so you can have a smaller case and save on space.
Video card comparisons:
960 vs 280: http://gpuboss.com/gpus/Sapphire-Radeon-R9-280-vs-MSI-GeForce-GTX-960
960 vs 280x: http://gpuboss.com/gpus/Sapphire-Radeon-R9-280X-vs-MSI-GeForce-GTX-960
280 vs 280x: http://gpuboss.com/gpus/Sapphire-Radeon-R9-280X-vs-Sapphire-Radeon-R9-280
In all three cases, gpuboss does not declare a winner. I wonder why!
Save your pennies. Go for the 280. In America, it's available for $150 on sale at least once a month.
Edit: I guess not America because technically that isn't very specific. I meant the U.S.
