When you overclock your CPU are you changing the boost clock or the base clock? And What happens to the turbo boost feature if you exceed the turbo boost clock itself? I'm confused..
I don't like 2D games...I just couldn't get into them.. ( ͡° ͜ʖ ͡°)
https://linustechtips.com/topic/373357-cpu-overclocking-advice/
You change the multiplier and voltage, base clock isn't recommended unless you know what you're doing or familiar with overclocking.
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
https://linustechtips.com/topic/373357-cpu-overclocking-advice/#findComment-5050796
You mainly just tweak the multiplier and the voltage these days. You can do more, but I suggest looking more into the details of how to squeeze every last power from the chip.
But just multiplier and voltage is good enough for the vast majority.
https://linustechtips.com/topic/373357-cpu-overclocking-advice/#findComment-5050804
I know but when you overclock to 4.5ghz for example is that your new base clock? Or is that the speed that the CPU will go to from its original base clock?
https://linustechtips.com/topic/373357-cpu-overclocking-advice/#findComment-5050808
That's your new base clock. What you're thinking of is adjusting turbo boost clocks or doing some sort of adaptive shit.
https://linustechtips.com/topic/373357-cpu-overclocking-advice/#findComment-5050841
That's the speed, your base clock should be "100" and when you set your multiplier to "45" it becomes "4500" in MHz which mean 4.5GHz
PC Specs
Indonesia
Australia
https://linustechtips.com/topic/373357-cpu-overclocking-advice/#findComment-5050861
