I have been saving up for a PC,And been setting up a build.This is what i have ATM.
 http://ca.pcpartpicker.com/p/rPJzxr
Feel free to comment back on what i should add or remove,I like AMD, and would like to stay with AMD.
Oh ya, Price range 950 CAD-1300 CAD,As i am 13. Rember CAD, as im in canada.
Case has to be under 18inches.
Thanks.
https://linustechtips.com/topic/373126-first-pc-build/
FX9590 + CM 212 Evo is a recipe for disaster
also your budget could fit a Intel+ AMD GPU combo easily
one sec
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/373126-first-pc-build/#findComment-5048332
WATER COOLING, IF U DONT WATER COOL THAT CPU U WILL HAVE A FIRE
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
https://linustechtips.com/topic/373126-first-pc-build/#findComment-5048335
That is true, even with a 240mm rad it throttles past 95c
You may need a custom loop
Intel Core i7 9700k - EVGA FTW GTX 970
https://linustechtips.com/topic/373126-first-pc-build/#findComment-5048346
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($285.00 @ Canada Computers)
Motherboard: Gigabyte GA-Z97X-SOC ATX LGA1150 Motherboard  ($119.99 @ NCIX)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  ($71.99 @ Memory Express)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($119.99 @ Canada Computers)
Video Card: PowerColor Radeon R9 290X 4GB TurboDuo Video Card  ($374.98 @ Newegg Canada)
Case: Corsair 450D ATX Mid Tower Case  ($124.99 @ Memory Express)
Total: $1216.91
Generated by PCPartPicker 2015-05-24 21:14 EDT-0400
https://linustechtips.com/topic/373126-first-pc-build/#findComment-5048350
the better way to spend $1300 CAD
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($34.98 @ NCIX)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($99.99 @ NCIX)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1600 Memory  ($67.99 @ NCIX)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($63.95 @ Vuugo)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card  ($399.99 @ NCIX)
Case: NZXT S340 (White) ATX Mid Tower Case  ($89.99 @ Memory Express)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($128.45 @ DirectCanada)
Total: $1290.33
Generated by PCPartPicker 2015-05-24 21:02 EDT-0400
https://linustechtips.com/topic/373126-first-pc-build/#findComment-5048354
i know you like AMD BUT TRUST ME.. iv been there and i noe understand that its just a mistake to use any fx part ryt now as its just the same cpu with different clock speeds.. fx 9590 is an overclocked 8350 get it.. whiles you can just buy an 8350 for like half the price..
Anyways ill come back with two systems one intel and One AMD.. then you choose
https://linustechtips.com/topic/373126-first-pc-build/#findComment-5048360
This is a good AMD build
http://ca.pcpartpicker.com/p/sVwzdC
https://linustechtips.com/topic/373126-first-pc-build/#findComment-5048365
If you want I could get a AMD, build too. Its just at this price point Intel is a better choice. Also I changed your color scheme to orange/blue, and its mATX now which is smaller
Motherboard: ASRock Z97M Pro4 Micro ATX LGA1150 Motherboard  ($124.98 @ NCIX)
Case: Corsair 350D MicroATX Mid Tower Case  ($103.88 @ Canada Computers)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($35.99 @ NCIX)
Total: $1328.63
Generated by PCPartPicker 2015-05-24 21:31 EDT-0400
Man I forgot a power supply so now it went over....
https://linustechtips.com/topic/373126-first-pc-build/#findComment-5048513
Total: $1328.63
980 is not worth the extra money over the 970 .. the 290X is better for the money
https://linustechtips.com/topic/373126-first-pc-build/#findComment-5048577
I know 2 970 beat 1 980, but 2 970 was $100 more expensive... and also there was a 970 that was cheaper then a r9 290x, and also you have to get a bigger power supply to sli or cross fire, so 1 980 is still cheaper...
https://linustechtips.com/topic/373126-first-pc-build/#findComment-5048592
What's the system being used for?
Under 18" tall?
Why such a large psu?
I liek good mans build, i will consider it, and thank you for telling me about the 9590 and 212.
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/373126-first-pc-build/#findComment-5049202
Under 18" tall?
I want it for gaming, and some light editing, as i want to record games.It has to be under 18" because of my desk,I dont need a huge PSU just one to power all of my things.
https://linustechtips.com/topic/373126-first-pc-build/#findComment-5051329
I don't see why you would want to stick with AMD. Something like this would be better: http://ca.pcpartpicker.com/p/qk4srH
https://linustechtips.com/topic/373126-first-pc-build/#findComment-5054580
I want to stick with AMD, because i dotn want to Overclock, as i might brake something, i know its easy, i just dotn want to.
Oc'ing isn't limited to Intel and the 9590 is meant for oc'ing.
https://linustechtips.com/topic/373126-first-pc-build/#findComment-5054897
I have looked at all the build suggestions, ATm i am willing to go with WoodMarker and Goodman's builds,
Goodman http://ca.pcpartpicker.com/p/sVwzdC
WoodMarker http://ca.pcpartpicker.com/parts/partlist/
I only added a cooler to WoodMarker's.
https://linustechtips.com/topic/373126-first-pc-build/#findComment-5054996
You need to post the permalink and not the url.
Why would you need an aftermarket cooler?
https://linustechtips.com/topic/373126-first-pc-build/#findComment-5055113
I dont like the look of the stock cooler,
Heres the correct link
WoodenMarker: http://ca.pcpartpicker.com/p/kKh3nQ
GoodMan: http://ca.pcpartpicker.com/p/sVwzdC
I also changed the CPU, because it was cheaper and was faster.
https://linustechtips.com/topic/373126-first-pc-build/#findComment-5055591
What's bad looking about the stock cooler? The Alpine 11 Pro looks pretty similar.
It's the same cpu.
https://linustechtips.com/topic/373126-first-pc-build/#findComment-5055655
The CPU was ment to be the i5 4460 @3.1GHz, i know its one more GHz but it was also cheaper.But i dont care too much any more.
The 4460 would need a Haswell-R ready motherboard like a h97 or z97 board and end up costing more.
https://linustechtips.com/topic/373126-first-pc-build/#findComment-5056318
