I'm going to make an Obsidian 350D gaming rig which will have a 4770K cooled by an H100. and my only problem is how should i arrange the fans to have the best airflow and maintain a positive airflow.
Main rig:
• Ryzen 3600X • X370 Killer SLI • 16GB Corsair LPX 3200Mhz • Strix 1070ti • Define R5 • SuperNova 750 G2 • Evo 1TB + X300 4TB •
Secondary rig:
• Acer prebuilt • Rzyen 1700X (upgraded) • OEM 1060 3GB • 256GB SSD + 1TB Seagate (upgraded) •
https://linustechtips.com/topic/37282-350d-cooling/
Front intake and rear exhaust will be fine.
https://linustechtips.com/topic/37282-350d-cooling/#findComment-479236
But then there would be 2 intake fans and 3 out blowing fans so the airflow would be negative.
Main rig:
Secondary rig:
https://linustechtips.com/topic/37282-350d-cooling/#findComment-479352
could you reverse it so the H100 and the back fan would be an intake and the front fans would be outtakes
Main rig:
Secondary rig:
https://linustechtips.com/topic/37282-350d-cooling/#findComment-479355
