Hi I was wondering if anyone could help. My computer is experiencing Generic Freezing, or system hang which it's often referred to. Everything stops working, internet stops, skype calls disconnects, music stops playing. Need to know how to fix this. Just built this PC couple days ago. Was thinking its a RAM problem, I only have one stick instead of two as I accidently bought the one stick module :(.
This is the RAM I have: http://www.amazon.co.uk/HyperX-FURY-1866MHz-Memory-Module/dp/B00J8E913Q/ref=sr_1_sc_4?ie=UTF8&qid=1432212178&sr=8-4-spell&keywords=8gb+hyper+x+ram+white
https://linustechtips.com/topic/371994-help-me-please-generic-freezing/
Definitely not a RAM fault, internet won't stop. Might be a faulty motherboard (What do you have), don't count me on that one though.
CPU: Intel Core i7 5960X @4GHz cooled by a Corsair H110i GT | MBO: Asus X99 Sabertooth | RAM: Crucial Ballistix Sport 32GB DDR4 (4x8GB 2400MHz) | GPU: Gigabyte G1 Gaming GTX 980 | SSD: Samsung SM951 M.2 SSD | HDD: 1TB Western Digital Black Drive | PSU: Corsair HX750i | Case: Corsair Obsidian 450D
Try updating the BIOS and see if that helps.
Not sure of any, sorry :/
Do you by any chance have another system to test hardware on?
Well, can't you swap it out and see if it's faulty? Or is it being returned :P
