CPU cooler fans
Go to solution Solved by MrJabbaCake,
I was looking at the SP 120's. I was looking for some with LED preferably, if not then they will do.
Never mind I found led ones :)
I am unsure what to get for my CPU fans. I am swapping out my custom fan on the truespirit for 2 new ones. I was thinking about getting 2 cm jetflows. My friend has 2 sickleflows and he said they work. Out of the two what is better? Are there any other cheap fans I can buy that will operate well ( mostly interested in looks but performance is also nice)
My build --- Intel i7 4790K @ 4.5 GHz --- ASUS STRIX GTX 980 4 GB --- ASUS Maximus VII ROG Ranger --- 32 GB Corsair Vengeance Pro 2133 MHz (4x4) --- CS750M 80+ GOLD --- 2 TB WD Black HDD --- Intel 730 240 GB SSD --- Seagate 1TB SSHD --- Cooler Master HAF X --- Thermal Right True Spirit 120 --- Windows 10
Peripherals --- Corsair K70 Cherry mx blue --- Corsair Sabre RGB --- Corsair MM200 Mouse mat --- Hyper X Cloud II --- LG 29UB65 29" --- LG 24M47VQ 24"
https://linustechtips.com/topic/371219-cpu-cooler-fans/
Get Static Pressure fans for heatsinks! Do not get air-flow optimized ones.
Corsair SP120's or SP140's if you're on a budget.
Noctua NF-A14/NF-A15 for best performance.
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
https://linustechtips.com/topic/371219-cpu-cooler-fans/#findComment-5025857
you do need to get fans which are static pressure optimized
between the two
the SickleFlow X has better air flow movement
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/371219-cpu-cooler-fans/#findComment-5025860
https://linustechtips.com/topic/371219-cpu-cooler-fans/#findComment-5025878
https://linustechtips.com/topic/371219-cpu-cooler-fans/#findComment-5025883
Most fans with LED's are air-flow optimized. SP120's are descent, but if you're willing to pay a premium, get Noctuas. they are the best manufacturer for fans.
https://linustechtips.com/topic/371219-cpu-cooler-fans/#findComment-5025892
Link??
https://linustechtips.com/topic/371219-cpu-cooler-fans/#findComment-5025895
https://linustechtips.com/topic/371219-cpu-cooler-fans/#findComment-5025925
