Currently using an "Antec Performance Max CPU Cooler" to cool my CPU. It does fine, about as well as a Hyper T4. Currently I have it facing vertical (the internal fan blowing up and out of my case) with 2x120mm fans above it, and 1x120mm front intake and 1x200mm side intake feeding air to it. If it turn it horizontal (internal fan facing rear exhaust 120mm) would the temps change at all? If so would the increase or decrease and by how much?
Extra note - I had to borrow some mx2 (I know its terrible but it works) when I assembled this. I now have some Antec formula 7 thermal compound. Would simply reapplying the paste do more help than the position of the cooler itself?
CPU: INTEL Core i7 4790k @ 4.7Ghz - Cooling: NZXT Kraken X61 - Mobo: Gigabyte Z97X SLI - RAM: 16GB G.Skill Ares 2400mhz - GPU: AMD Sapphire Nitro R9 Fury 4G - Case: Phanteks P350X - PSU: EVGA 750GQ - Storage: WD Black 1TB - Fans: 2x Noctua NF-P14s (Push) / 2x Corsair AF140 (Pull) / 3x Corsair AF120 (Exhaust) - Keyboard: Corsair K70 Cherry MX Red - Mouse: Razer Deathadder Chroma
Bit of an AMD fan I suppose. I don't bias my replies to anything however, I just prefer AMD and their products. Buy whatever the H*CK you want.
---QUOTE ME OR I WILL LIKELY NOT REPLY---
https://linustechtips.com/topic/371037-cpu-cooler-placement/
Orientation has as little effect on temps as push or pull config for fan. You may get better results by rethinking whole airflow setup. Like remove side fan and make top fan intake too. That would feed more cool air straight to CPU if thats the one needing it most. Side fans usually feed air more towards GPUs.
(On side note, difference between horizontal and vertical is 3C in favour of horizontal. U14S)
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/371037-cpu-cooler-placement/#findComment-5029307
