Can someone please help?
Go to solution Solved by c_marriott,
I'll look a bit more into it for you, but for now I can suggest heading over to the community forums for the Z1C: here
or possibly get into contact with Sony and ask for their help.
EDIT: Spelling
EDIT 2: Link
Video link, this may help solve it
So, I was having trouble using Sony's update center to update my Xperia Z1 compact to Android 5.0.2, so I used Sony PC companion to attempt this. Everything seemed to be going fine and dandy until the process froze towards the end (right after optimizing all my apps) and now I'm stuck with the black screen of death. Well, it's not totally black as the notification bar is there, and the holding down power buttons works. Everything else though is completely unresponsive. Does anyone know how I can reset this thing or get it working?
https://linustechtips.com/topic/371017-can-someone-please-help/
take out the batery and then put it in and boot your phone, might work might not who knows untill you try!
Builds:
https://linustechtips.com/topic/371017-can-someone-please-help/#findComment-5023048
Sorry, not relevant, but what network is your phone on? I'm on EE and i still haven't got the update :( Also, did you back up your device beforehand? If you did try to use that if not then there should be a repair tool in PC companion, that may work?
CPU: FX-6300 GPU: Sapphire R9 380X MOBO: Gigabyte 970A-DS3P RAM: Corsair Vengeance 8GB PSU: XFX XTR 550W CASE: Zalman Z11 Plus SSD: Samsung 840 Evo
17 years old, PC Enthusiast for 3. Be gentle with me, I'm only young.
https://linustechtips.com/topic/371017-can-someone-please-help/#findComment-5023156
EDIT: Spelling
EDIT 2: Link
https://linustechtips.com/topic/371017-can-someone-please-help/#findComment-5023247
That worked! Thank you so much! I'm going to go download all my apps now. Thanks for the help!
No problem, glad to help :)
https://linustechtips.com/topic/371017-can-someone-please-help/#findComment-5023557
