the 8800 gt is better for gaming but if your doing 3d work quadro better
My Old Rig: Phenom II X4 965 4.0 ghz, Asus Motherboard, 4 GB DDR3-1333, Antec Case and PSU, no video card atm
My New Rig: i5-4590, MSI Motherboard, 8 GB DDR3-1600, Corsair Case, XFX PSU, HD 7950
https://linustechtips.com/topic/370616-card-comparison-help/#findComment-5017980
I want to get titanfall, the 8800 is the minimum, can my card hold up?
you'd have to play at low settings for the 8800 gt, maybe around 20 fps on 1080p
https://linustechtips.com/topic/370616-card-comparison-help/#findComment-5018003
If you have the Quadro, it will not. THe FX1800 has far fewer cuda cores than the 8800GT, with a smaller memory BUS (but 256MB more memory).  You will need an upgrade.
Desktop <dead?>
P8P67-WS/Z77 Extreme4/H61DE-S3. 4x4 Samsung 1600MHz/1x8GB Gskill 1866MHzC9. 750W OCZ ZT/750w Corsair CX. GTX480/Sapphire HD7950 1.05GHz (OC). Adata SP600 256GB x2/SSG 830 128GB/1TB Hatachi Deskstar/3TB Seagate. Windows XP/7Pro, Windows 10 on Test drive. FreeBSD and Fedora on liveboot USB3 drives.
Laptop <Works Beyond Spec>
HP-DM3. Pentium U5400. 2x4GB DDR3 1600MHz (Samsung iirc). Intel HD. 512GB SSD. 8TB USB drive (Western Digital). Coil Wine!!!!!! (Is that a spec?).
https://linustechtips.com/topic/370616-card-comparison-help/#findComment-5018013
I'm using the 1800, can that hold?
No. It is below the 8800GT in performance.
Desktop <dead?>
https://linustechtips.com/topic/370616-card-comparison-help/#findComment-5018022
no. but why are you getting the 8800 gt? that card is old
https://linustechtips.com/topic/370616-card-comparison-help/#findComment-5018026
Back when I had the 9800gt, it ran the Titanfall beta thing pretty well (max or mostly high settings and very playable framerates at 1280x1024), but I can't remember if that was before I got my 1080p monitor.
https://linustechtips.com/topic/370616-card-comparison-help/#findComment-5018042
