I have a ASRock killer 990fx mobo, also I tested out my new K70 RGB and the USB 3.0 has been left unoccupied for some times now. I did a Driver Update and all just that when plug into the USB 3.0 no flash stick and cable are able to be detected. I even gone to the ASRock site and download the newest software update and it did not do anything. I just mad at ASRock making such thing that does not work. I try Disable and Enable the USB 3.0 Legacy in Bios, does not do anything. Im already using tons of USB 2.0 slot. I still want to save the USB 2.0 for other thing rather than eating up every single slot. I Need help on fixing this.
 20150520_10482100.jpg?lgfp=3000
https://linustechtips.com/topic/370253-asrock-usb-30-help/
i have the exact same problem my usb 3.0 doesn't recognize any of my stuff but thats no problem for but interested but what kind of stuff are you plugging in?
edit also from asrock ;/
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
https://linustechtips.com/topic/370253-asrock-usb-30-help/#findComment-5013526
All on USB 2.0
Mouse
Wireless Keyboard
Ipod
Galaxy s5
Extension Cable- Headphone
The last 2.0 is swapable flash stick 2.0 for daily work.
USB 3.0 nothing occupying which it leaving space for nothing.
https://linustechtips.com/topic/370253-asrock-usb-30-help/#findComment-5013573
can you go to the device manager and maybe give me a screenshot of the universal serial bus controllers or just type it ?
it might be broken or it might still be a software problem
https://linustechtips.com/topic/370253-asrock-usb-30-help/#findComment-5022139
All on USB 2.0
Mouse
Wireless Keyboard
Ipod
Galaxy s5
https://linustechtips.com/topic/370253-asrock-usb-30-help/#findComment-5022142
