Do Micro ATX mobos fit in ATX Cases
It always says which types will fit in your case under specifications of any "Info-Sites"
Motherboard Type: mATX, ATX
So in your case (<- lol get it? "case", moving on...) yes it will fit, it simply depends on the pre-drilled holes in your case, which smaller types will fit in it.
Edit: Unintentional LTT reference on the LTT forums ! SORCERY !
CPU: i7-4770k (LM modded) - MB: GA-Z87X-UD3H - RAM: HyperX, 16GB 1866MHz - GPU: Palit GTX 980Ti Super - Storage: 1TB HDD + 500GB/120GB SSD (850 Evo/840) - Monitor: Predator XB271HU - PSU: 700W BeQuiet 80+ Gold
https://linustechtips.com/topic/370228-will-these-parts-work/#findComment-5013212
