Help with my first Build
Solved by TrickedProGaming,
because I already have 2x4GB at home and not in use.
Do I have any disadvantage of it expact the fact that i can't add more without switching them?
There won't be any disadvantage of 4x4GB if you don't plan to upgrade later if you already have 2x4GB in your house. (Sorry for my late reply btw)
