Case Compatibility Corsair 500R
Solved by SageC,
Well my dad is really good at that stuff so I would probably have him do it, because construction type stuff I am decent at drilling but my dad is better and that way I can blame someone if it is messed up but I switched from the Corsair to NZXT for the better airflow and I feel like it is better quality, though I will be using the software for the K70 RGB keyboard.
Well if you're dad knows what he is doing it shouldn't be too difficult, just make sure you're precise in marking where the holes should go. I think overall the NZXT cooler is much better, it should give you better temperatures and the CAM software actually works which is always a bonus.
