Err I was playing some Minecraft and I decided to check my GPU temps on CAM I have an R9 290x 8GB (the yellow one) and it was hitting something quite high like 86c but the app was glitching it was saying it was 83.00000001 and the load kept going above 100 so like 934 for some reason.... is the CAM because the rest of my hardwares temps were fine but feeling the side of the PC it was very hot.... I have about 5 fans and a watercooler in my system so are the temps supposed to be like this?
https://linustechtips.com/topic/369804-hot-hot-gpu/
The card's designed to run at 95c it will be fine at any temps below that.
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/369804-hot-hot-gpu/#findComment-5007197
Are you using shaders?
Just set a limit on your fps in minecraft, (I do 120 personally) and it should bring temps down.
CASE: Phanteks Enthoo Pro // CPU: Intel Core i5 2500K @4.2GHz // GPU: NVIDIA GeForce GTX 970 Reference // RAM: 16GB Crucial Ballistix Sport @1333MHz // MOBOASUS P8Z77-V LK // SPACE: 240GB Crucial M500 SSD ~ WD Black 1TB // PSU: Corsair CX750M //
CASE: Cooler Master Elite 130 // CPU: Intel Pentium G3258 @4.0GHz // GPU: N/A // RAM: 8GB Crucial Ballistix Sport @1600MHz // MOBOEVGA Z87 Stinger Mini-ITX // SPACE: OCZ ARC 100 120GB SSD ~ [2X WD Black 2TB in RAID 1] // PSU: EVGA 430W //
https://linustechtips.com/topic/369804-hot-hot-gpu/#findComment-5007217
The 280/285/280x is not designed to run at 95c, only the 290/290x are capable of running at that temp for extended periods without damage.
@OP when was the last time you cleaned the GPU? try using MSI Afterburner to get your GPU temps to confirm that the software you're using is showing the correct temp.
"The of and to a in is I that it for you was with on as have but be they"
https://linustechtips.com/topic/369804-hot-hot-gpu/#findComment-5007259
Yeah I have tried different Softwares all about the same off by like 2-7c (78) On afterburner
https://linustechtips.com/topic/369804-hot-hot-gpu/#findComment-5007271
And he does have a 290X.
https://linustechtips.com/topic/369804-hot-hot-gpu/#findComment-5007275
But not the stock one... Is it still Okay?
Yes it's fine.
https://linustechtips.com/topic/369804-hot-hot-gpu/#findComment-5007285
Are you overclocking?
what case do you have is the gpu getting enough air flow?
Is the card dusty?
try using programs like speedfan to make sure its not just your programing spitting out numbers
I  have GameServer`s And VOIP servers the only price is that you have fun on them.
https://linustechtips.com/topic/369804-hot-hot-gpu/#findComment-5007301
Is the card dusty?
No
Yes, BitFenix Ronin with the side panel off.
Nope or doesnt look like it.
I have done roughly the same :)
https://linustechtips.com/topic/369804-hot-hot-gpu/#findComment-5007321
