So, i want to build a 1500€ PC
I used a german retailer (since i live in germany) to match the 1500€ limit...
I used the following parts:
CPU: Intel i7 5820k
Ram: 16gb DDR4 Corsair Vengeance LPX Quadkit
Graphics: KFA2 GTX 970
PSU: 650Watt CoolerMaster G650M
HDD: 3TB WD Red
SSD: 120gb Samsung 850 Evo
Case: NZXT Source 340
CPU Cooler: CoolerMaster Nepton 120XL
Mainboard: MSI X99S
All parts are based on the pricelist from http://mindfactory.de
What do u guys think? Is this actually worth the 1500€?
How does it perform in terms of 4k gaming? Is it worth to overclock this beast?
I am open to suggestions
thanks for all replys
greetings from the volks over from germany! :D
https://linustechtips.com/topic/369758-first-own-pc-build/
IF you are only wanting to game you can do much better for the money.
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/369758-first-own-pc-build/#findComment-5006604
They.. Make.. Wd red? Go,for a caviar or WD blue or Black series. Get a 250-500gb SSD. Drop down to a 2tb HDD. Get a i5-4690k instead. Betime you save money on ram, and the mobo bo AND the CPU. Upgrade to a GTX 980, you can 4k with a GTX 980 but a Titan X or 980 SLI is better. 980 will perform slightly better but be limited by VRAM once you are in advance settings.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/369758-first-own-pc-build/#findComment-5006642
