CPU advice
Go to solution Solved by EmeraldKiwi,
If you are going for the 280x, try to get at least 600w. A single GPU doesn't present much of a power limitation, even if its a 280x. 600w will go pretty far. I used one with an AMD 4150 and a 7870 , both over clocked to the max, and there was still no power limitations. If you plan to get a second GPU in the future, get a 700-900w to leave the most possible room for excess power draw. Otherwise,
TL;DR:
600w is fine for your current build.
EDIT:
karlsanada13 from Toms hardware previously solved a topic about the best 600w PSU. He said,
"Seasonic M12II 620w 80+ Bronze
or the same psu but with S12II.
M12II = modular
the other is not but it's the same psu all-around."
Hey I need some piece of advice in regard to an intel CPU.
So got a r9 280x vapor-x but I don't know which CPU to go with. Pricerange is 200 to 250€ max.
I thought the Core i5-4590 would be great but it costs 204€ and the core i5-4690 226€.
The PC will be used for gaming (as far as the r9 280x can handle it) and work for school or uni no videoediting or rendering.
Can i theoretically pick a Pentium G3250 or an i3 without bottlenecking my GPU?
would be awesome if someone can help me out.
https://linustechtips.com/topic/369557-cpu-advice/
The i5 4590 would be more than enough.
https://linustechtips.com/topic/369557-cpu-advice/#findComment-5003856
but the 4690 costs 23€ more..
edit: so is there no cheaper option for the work i will do? I would pick an i5 since they are not really expensive but will i need an i5?
and I've got another question: will a 600W PSU get the job done or do i need a 750W?
http://de.pcpartpicker.com/p/bG3hrH
https://linustechtips.com/topic/369557-cpu-advice/#findComment-5003867
and... i believe you can't see any fps gaining over the 4690
https://linustechtips.com/topic/369557-cpu-advice/#findComment-5003890
The 4590 is probably fine. I don't know what socket it is, but try to grab an LGA 1150/1155 to leave room for a better CPU in the future if you want. It saves in the future because you won't have to replace the motherboard, unless you want to.
I'm not SAV1OUR. I promise. | Number of successfully bricked phones: 1 Samsung Galaxy S5 | 01001001 01110100 00100000 01110111 01100001 01110011 00100000 01100001 01101100 01101100 00100000 01100001 01101110 00100000 01100101 01101100 01100001 01100010 01101111 01110010 01100001 01110100 01100101 00100000 01110010 01110101 01110011 01100101 00101110
https://linustechtips.com/topic/369557-cpu-advice/#findComment-5003901
Thanks guys I'll stick to the 4590 :)
 and yes the mobo has got an LGA 1150 just like the 4590.
However, i still need help in reagrd to the PSU what would you recommend?
https://linustechtips.com/topic/369557-cpu-advice/#findComment-5003922
TL;DR:
EDIT:
M12II = modular
https://linustechtips.com/topic/369557-cpu-advice/#findComment-5003962
TL;DR:
600w seasonic
thank you. I'm going for the 600w since I don't think that I am going to have 2 GPUs in my system in the future.
https://linustechtips.com/topic/369557-cpu-advice/#findComment-5003991
