Former PC noob here with my tweaked and perfected (?) build for a gaming PC.
My budget is around €1200,- and I live in The Netherlands.
I will use my pc for general browsing and I want to play games on high graphics. Now I don't need to play everything on Ultra High, but High or Very High would be great. Heres my build:
CPU: Intel Core i5-4460 Boxed (no additional cooler)
Motherboard: ASRock Z97 Anniversary
Memory: Crucial Ballistix BLS2CP4G3D1609DS1S00CEU
Storage: WD Black SATA 6 Gb/s WD2003FZEX, 2TB
Video CardMSI GeForce GTX 970 4GD5T OC
Case: Corsair Carbide 200R Closed
Power SupplySeasonic G-series 650 watt
SSD: Crucial BX100 250GB
Monitor: BenQ GL2460HM
I also got a PCPartpicker link but it comes with a few notes:
http://pcpartpicker.com/p/hXNVXL
- The case on the list is the Corsair 200R, while I actually want the Corsair Carbide 200R, but I think these are the same?
- The memory I chose is the Crucial Ballistix BLS2CP4G3D1609DS1S00CEU, but PcPartpicker only had the BLS2KIT4G3D1609DS1S00. Are these the same or do ''CP'' and ''KIT'' make a (big) difference?.
I won't be overclocking so no CPU cooler should be fine. Also I found out there are tons of different GTX 970 versions out there. Any tips whether I can get a better one for around the same prize?
As I said this is my first build, what do you think?
https://linustechtips.com/topic/369228-first-build-gaming-pc/
They are both the same thing, don't worry about it
“When life gives you lemons, don’t make lemonade. Make life take the lemons back! Get mad! I don’t want your damn lemons, what the hell am I supposed to do with these? Demand to see life’s manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I’m the man who’s gonna burn your house down! With the lemons! I’m gonna get my engineers to invent a combustible lemon that burns your house down!”
- Cave Johnson, founder and CEO of Aperture Science, in Portal 2
https://linustechtips.com/topic/369228-first-build-gaming-pc/#findComment-4999075
-snip-
If your not overclocking dont spend the extra money on a z-series motherboard, go for an h- series. also you should look at a 500w psu, 650 is overkill.  as for the gpu I personally like evga because of their customer service but their ACX coolers are just a little less quiet than other aftermarket coolers. also please follow your own threads.
Intel 3570k @ 4.4 GHz |Asus Sabertooth Z77 |EVGA GTX 660 Ti FTW |Kingston HyperX Beast 16 Gb DDR3 1866 (2x8Gb)
|Samsung 840 250 GB |Western Digital Green 2TB 2x |Cooler Master 850w 80+ Gold |Custom Water Cooling Loop |Noctua NF-F12 4x
|Noctua NF-A14 3x |Corsair Carbide 500R (White) |Corsair K95 |Razer Mamba |Razer Megalodon |Samsung SyncMaster T220 2x Computer Bucket List   Greatest Thread Ever   WAN Show Drinking Game  GPU Buyers Guide
https://linustechtips.com/topic/369228-first-build-gaming-pc/#findComment-4999079
To answer your questions at the bottom of your post:
- The 200R and Carbide 200R are the same thing. People just tend to shorten it by cutting out Carbide, and just saying 200R. Although I would not suggest this case, as I have it and the cable management room is not very big, and I struggle to get the right side panel on and off with all the cables up against it. I suggest that you spend $30 more and get a Corsair 450D.
- I do not know the answer to your second question regarding the memory, maybe someone else can answer that.
- And even if you are not overclocking you will NEED a CPU cooler. The stock cooler will work fine, but if your CPU does not include you need to buy an aftermarket cooler.
- I would suggest the Gigabyte G1 Gaming 970, or the Asus Strix 970.
RIG: CPU: i5 6600k @4.8GHz 1.34v  CPU Cooler: H100i  Motherboard: Asus Z170-AR  RAM: Corsair Vengence LPX 2400 (2x8GB)
HDD: Seagate Baracuda 2TB  SSD: Samsung 850 Evo 500GB/PNY 240GB  GPU: Gigabyte G1 Gaming GTX 970  PSU: EVGA G2 650W
Please use PcPartPicker, and paste the "BB" code when posting your build!
https://linustechtips.com/topic/369228-first-build-gaming-pc/#findComment-4999081
http://uk.pcpartpicker.com/p/b8sdWZcheck out the th case, the noctis 450 is also nice, but if you like the 200r go for it :)
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/369228-first-build-gaming-pc/#findComment-4999094
i suggest going for either a H97 motherboard, or an i5 4690K, because a non-K cpu in a Z97 mobo is just a weird combo.
and PLEASE get a decent cooler on there, this comes from someone with an i3 560 with a stock intel cooler:
the stock coolers are fine, until dust hits, and they go louder, and louder.
my 560 (w/ stock) is louder at idle than my 4790K(w/ dark rock advanced C1) at full load.
https://linustechtips.com/topic/369228-first-build-gaming-pc/#findComment-4999142
Change the motherboard to the h97 series. Are you going to get another 970 in the future? Your psu is overkill for that build.
Love cats and Linus. Check out linuscattips-fan-club. http://pcpartpicker.com/p/Z9QDVn and Asus ROG Swift. I love anime as well. Check out Heaven Society heaven-society. My own personal giveaway thread http://linustechtips.com/main/topic/387856-evga-geforce-gtx-970-giveaway-presented-by-grimneo/.
https://linustechtips.com/topic/369228-first-build-gaming-pc/#findComment-4999199
~snip~
Hey Wrench and welcome to Linus Tech Tips forum :)
This is a nice planned build. It should cover your demands.
As the guys said, the motherboard supports CPU overclocking and multiple GPUs while the CPU that you have chosen is locked and can't be overclocked.
WD Black is a great performance drive designed for heavier workloads and gaming. :) Good choice.
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/369228-first-build-gaming-pc/#findComment-5002321
