I bought a Corsair H100i, but decided to return it as I also got a Corsair 550d and didn't want the top panel of the case opened because it defeated the purposed of the 550d's sound dampening design. I've got a few bucks to spend (less than $100) and I'm wondering what air cooler I should purchase. I was looking at single 120mm liquid coolers like the H80i but I've heard they are just as loud as a air coolers and just as good at cooling. I'm looking for something extremely quiet but also something that cools good because my i7 2600k runs at 4.6ghz and the 550d has restricted airflow. I've looked at the hyper 212 evo, but it is only $40 is there something better I can get and spend a bit more?
https://linustechtips.com/topic/3685-h100i-replacement/
Look at Noctua or Phanteks - both awesome air cooling solutions...
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/3685-h100i-replacement/#findComment-45708
Look at the h220 from swifttech its really great low noise plus it has better performance then a h110i but you need to wait till the 20th Feb.
Hardware: Intel I7 4790K 4Ghz | Asus Maximus VII Hero Z97 | Gigabyte 780 Windforce OC | Noctua NH-U12P SE2 | Sandisk Extreme Pro 480GB | Seagate 500Gb 7200Rpm | Phanteks Enthoo Luxe | EVGA Supernova G2 850W | Noctua NF12 | SupremeFX 2014 | Patriot Viper 3 16GB.
Gaming Gear: Cooler Master TK Stealth | Sennheiser PC350SE | Steelseries Rival | LG IPS23L-BN ' 5ms | Philips Brillians 144hz
https://linustechtips.com/topic/3685-h100i-replacement/#findComment-45755
From what I've seen Vapor-X su**s. Cheap, quite and powerfull is Thermalright HR-02 Macho (you can get a black and white version - just add BW at the end)
PC: CPU: Intel i7-4790 MB: Gigabyte B85N RAM: Adata 4GB + Kingston 8GB SSD: Samsung 850 EVO 500GB GPU: XFX GTR RX 480 8GB Case: Advantech IPC-510 PSU: Corsair RM1000i KB: Idobao x YMDK ID75 with Outemu Silent Grey Mouse: Logitech G305 Mousepad: LTT Deskpad Headphones: AKG K240 Sextett
Phone: Sony Xperia 5 II
https://linustechtips.com/topic/3685-h100i-replacement/#findComment-45923
He can't, because he returned the H100i because of size/location issues he needs either air or a 120 Rad cooler.
https://linustechtips.com/topic/3685-h100i-replacement/#findComment-45955
Here's a post I found on another forum that confirms that a Noctua NH-D14 will fit in a 550D. I think the Phanteks is slightly taller than the Noctua, but it's going to be a tight fit either way.
http://www.overclock.net/t/1256647/corsair-550d-owners-club/130
I think they're both great coolers, I'm planning on getting a Noctua when I do my rig upgrade in the next month or so.
"Wisdom III" AMD FX 8120 @ 4.1Ghz // Biostar TA990FXE // 16GB GeIL Black Dragon (8x2) // Saphire HD 7870 OC Edition // CORSAIR TX850M // Curcial M4 64GB (boot) // Seagate Barracuda Green 1.5TB (storage) // Cooler Master Hyper N 520 // Windows 7 Pro 64 bit
https://linustechtips.com/topic/3685-h100i-replacement/#findComment-45980
