Hey guys building a pc for the first time, need some help
I got this psu      https://pcpartpicker.com/part/evga-power-supply-120g10750xr
and i want to get that sweet look that comes from individually sleeved cables, but i cant seem to find any sets that are compatible
i was also recommend extensions, but idk which would work and which i need
i think i only need the mother board and the graphics cards extension cables as well as the extensions to connect them back to the psu as i think those are th only ones really visible ( correct me if im wrong)
If anyone could link me the cables i need, preferably at a good price, id be very grateful.
thank you
https://linustechtips.com/topic/368024-individually-sleeved-cables/
If you are looking for extensions how about you get our ModFlex Sleeved Wires? This way you can assemble the extensions in your color of choice without breaking your bank. :)
http://www.performance-pcs.com/catalogsearch/result/?q=CM-MSW
Let me know if you got any questions.
  • 3 weeks later...
How would you acomplish single to dual 8 pin PCI-E when making your own cables?
This method, I've done it before and it works pretty well:
-https://www.youtube.com/watch?v=uXaKt-tiVI0-
Corsair sells sleeved color cable sets
The Corsair sets are specific to certain Corsair PSU's.
  • 4 weeks later...
I was wondering if instead of using these as extensions you could just get another male adapter and use it as a complete power cord for your stuff(trying to get custom cables but not enough room in matx to do extensions
[spoiler=Blue^3http://linustechtips.com/main/topic/388528-blue3/ I5 4690k | Asrock Z97 Pro4 mATX | RAM: Corsair Vengeance (2x4GB) Blue Edition and Corsair Vengeance (2x4GB) Black Edition | GPU: XFX DD R9 390x | PSU: Corsair AX760 | SSD: Samsung 840- 120GB | Hard Drives: 2x1TB WD Blue | Watercooling Kit: XSPC Raystorm 240
thank you
I'd recommend @modguru. I have their extensions on my build and they are sweet.
CPU - i7 8700K / Motherboard - ROG Strix Z370 E/ RAM - 32GB Cosair Vengeance DDR / GPU  - GTX 1080ti - EVGA FTW3 / PSU - Seasonic Snow Silent 750W / Cooling - Cryorig H7 Monitor - Acer X34 Predator / Sound - Corsair Void - Case - Meshify C
